Old 06-11-2011, 04:11 PM
DianneB DianneB is offline
Rep: 74 Posts: 83
Chrysler A-225 overheated - now noisy
Hi guys! Dianne here aboard my 1966 Lonestar on beautiful Lake of the Woods in N.W. Ontario. I haven't been around much - been busy getting ready for the too-short boating season!
I ran into a bit of a problem .... probably should have changed the pump impeller but I didn't .... When I launched the cooling system didn't prime and the engine somewhat overheated by the time I moved from the ramp to my slip, maybe 10 minutes and the gauge was reading about 240. When I was trying to get the pump to pick up, the exhaust was blowing backward thru thecooling system. I did get the cooling system going but now, shortly after start-up I get this rattling noise like loose tappets or something rattling in the drive train and te noise stays. Everything looks normal - no blue smoke, no blow-by from the crankcase vent so I don't think I buggered it badly but something isn't right.
I will try new sparkplugs but what else could have been effected by overheating? I hope I didn't crack the block!!!
Thanks!
Old 06-11-2011, 08:17 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
what is the drive train, shaft/sterndrive?
photos?
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 06-11-2011, 08:59 PM
Rep: 74 Posts: 83
Volvo Penta 270
Old 06-11-2011, 09:08 PM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 655
you should not have exhaust blowing back through the water jackets. either a cracked head or corroded manifold. the tappet noise sounds like compression leaking not tappets. do a compression check before you try anything else. that is very important, without compression readings it is just guess work.
brendan .
Old 06-11-2011, 09:39 PM
Rep: 1493 Posts: 7,447
If the water pump is not pumping water, the exhaust gases will back up into the block. It is not a problem. What is the oil pressure?
Old 06-12-2011, 02:34 AM
Rep: 247 Posts: 655
i didn't realise that, i have never run an engine dry for more than a few seconds. so you don't think a compression check should be done. it is the first thing i would do.
brendan .
Old 06-12-2011, 08:00 AM
maybe burnt the exhaust bellows (transom plate to drive)and its flapping around?
Old 06-12-2011, 12:10 PM
Rep: 3125 Posts: 9,399
You could have a number of problems, though it should be pointed out the slant 6 Chrysler engine you have is a solid tappet engine, not hydraulic if memory serves me correctly. If she got good and hot you may have bashed down the tops of the lifters and they need to be adjusted, if not one or two replaced.
The wise thing to do is a full inspection, checking for cracks in the manifold and other likely common problem areas. Check the valve clearance when you pull the valve cover and this will tell you about the lifters.
Old 06-12-2011, 01:00 PM
Rep: 74 Posts: 83
Excellent point Par! I will put that on my check list for next trip to the boat.
Fortunately I have a Mercruiser 3.0 + Yamaha outdrive but if I have to do a swap, that will take most of the summer so I am hoping I didn't hurt the slant six.
You are correct - it is solid lifters - and it does sound a little like valve-train noise but it isn't immediate. After starting, it takes 20 to 40 seconds before the noise becomes apparent. It isn't a horrid noise - only someone familiar with that engine would realize it was abnormal.
Old 06-12-2011, 04:43 PM
GTS225 GTS225 is offline
Rep: 23 Posts: 32
Dianne; I am a slant enthusiast, even to the point of racing one, although it's in auto drag racing. I'm not able to diagnose your problem, but you might want to go to http://www.slantsix.org/
There's a good number of folks much more knowledgable than I, and they may be able to give you some more accurate ideas as to where to look.
You'll have to register in order to post, but for someone owning a slant, it's a very good informational resource.
Roger
Noisy engine 3.0 mercruiser TKS Logan1500 Gas Engines 17 12-23-2011 01:44 PM
How to quiet noisy exhaust? Brands01 Diesel Engines 51 11-15-2010 08:23 PM
mercruiser v6 overheated mark_fitzy Sterndrives 2 04-20-2009 04:44 AM
Overheated Suzuki Outboard Thin water Outboards 5 09-16-2007 04:58 PM
Engine Overheated - Help!! FourWinnsChic Sterndrives 2 08-31-2007 01:51 PM
