Old 04-12-2011, 03:55 PM
sean-nós's Avatar
sean-nós sean-nós is offline
Rep: 286 Posts: 103
Chevy V8 cooling
Hi, guys I am rebuilding a v8 for my crackerbox build and have bought a lot of chrome parts one of witch is a crossover pipe at the top of the photo that goes in place of the water pump, dose that mean I can run the engine and cool the 1-1 gearbox off the raw water pump and do away with the circulating pump. If any one has a diagram or photo or any advice on how it can or should be done please let me know thanks.
http://www.boatdesign.net/forums/att...1&d=1302641557
Old 04-12-2011, 07:54 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
I wouldnt use a crossover and replace the water circ pump if you operate in cold water
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 04-12-2011, 09:15 PM
mr hot rod's Avatar
mr hot rod mr hot rod is offline
Rep: 31 Posts: 12
Fergal,
Your kit should also include a thermostat.
We couldn't find any installation instructions for the SBC, but the BBC installation is similar :
BBC Water Inlet Crossover Kit with Bypass Installation Instructions
We've installed the Hardin Marine 4-Port Thermostat Kit on our 355. Click here for Installation Instructions.
120, 140, 160 and 180 degree hi-flow brass marine thermostats are also available.
A high quality sea strainer will ensure that the thermostat doesn't plug up with silt or debris.
Paul Kane Chelsea, PQ
Building the Glen-L Hot Rod : http://www.boats.chelseacoachworks.com
Old 04-14-2011, 02:19 AM
sean-nós's Avatar
Rep: 286 Posts: 103
Thanks mr hot rod thats a great help, I wasn't expecting you to pop up.
Old 04-15-2011, 06:22 PM
cyclops2 cyclops2 is offline
Rep: 94 Posts: 234
If you have no need to race flatout for long periods. Use a thermostat of about 130 to 140 F. That really slows down the salt deposits in the water cooled exhausts passages.
A check of every spark plug will tell you how the cylinders are running. You want a look like a cup of Coffee & some cream in it. Light brown.
Very light brown is NOT GOOD. Too lean of a cylinder condition. Burning of valves & possible knocking on hot days after a W O T run.
Hershey dark brown is too rich or a too cold thermostat....also a stuck thermostat in the open position.
Dark brown plugs CAN be VERY hard to prevent random misfiring in the engine. Too many dark plugs make for VERY DIFFICULT startups.
I do wander.
Rich
Old 04-16-2011, 06:00 AM
sean-nós's Avatar
Rep: 286 Posts: 103
Will I need to put in a water pressure regulator valve also.
This is all new to me so excuse the questions, I was just thinking that when the boat is moving at speed there will be a lot more pressure been put on the head gasket.
Are there any down sides to a crossover pipe in place of a circulation pump.
Thanks again.
Old 04-16-2011, 06:48 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
Sean I have admired the quality of your work in the past ,may I ask why you have decided not to use a heat exchanger?
Old 04-16-2011, 06:54 AM
Rep: 94 Posts: 234
Sean
I Hang around with a bunch of old race boat guys. The old wooden race boats. That also includes all types of Garvies, Skiffs & Crackers.
If you can wait a few days I may be able to get the best racing engine mechanic in the Saint Lawrence River area to get on the phone with you about how to cool any chevy.
Rich
Be sure to ask about the gearbox cooling. If you are just going to do vintage ....flybys....& NO blood & guts stuff tell him.
Old 04-16-2011, 11:09 AM
sean-nós's Avatar
Rep: 286 Posts: 103
Thanks Anthony this is my donor engine and it has a wet exhaust so I want to use as much as I can to save a few €€€ as I am building this boat on a very tight budget in fact no budget
Thanks cyclops2 If you could just ask is it a good or bad way to go in their opinion or what way they like to cool their engines that would be great thanks.
PS I would love to see any photos of crackerbox's you might have
Old 04-16-2011, 03:15 PM
Rep: 94 Posts: 234
Wiil do.
Old 04-17-2011, 07:15 PM
Rep: 94 Posts: 234
My 2 old crackerboxes.
They are pretty well emptied by now.
Rich
Old 04-18-2011, 06:20 AM
Thanks again.
I would as a non circ pump engine is very reactive to the water pressure so the pump needs to be sized perfectly
I would also fit an oil temp gauge to ensure the oil gets hot enough
You didnt mention your boating water temp or range of temps the engine has to operate in.
PS One thing that is true is that your donor engine cooling system design works perfectly
Chevy/GMC parts WickedGood Marketplace 3 01-17-2011 08:15 AM
454 chevy engine fritzer Gas Engines 3 07-08-2008 10:21 PM
converting from fresh water cooling to keel cooling Big H Buck Diesel Engines 9 07-06-2008 06:02 PM
Marinized Chevy diesel seo DIY Marinizing 1 03-12-2007 04:53 PM
283 sb chevy ktw1123 Gas Engines 10 09-12-2006 10:08 AM
