Old 08-10-2008, 09:06 PM
j2oh2o j2oh2o is offline
Rep: 10 Posts: 2
carb float adjustment
I Just purchased an old 73 bedaruin with a 302 ford and a volvo outdrive. From the start, I had problems with the engine bogging down after it warms up. I found out someone removed the ballast resistor for the ignition coil. I fixed that, but I still have a problem at high speed and sharp turns. I have the old 4160 Holly carb. I dont think the carb is marine application because it doesn't have the j vent tubes. I'm guessing it's not because its so old. I took it apart and it looks the same as my 4160 on my truck. Here's my main question.... Where should I put the float setting because if I put the level right at the hole on the side of the carb like you would with a vehicle, it still cuts out. The more I Raise the feul level the better it gets, but I just dont know if this is right.
Old 08-11-2008, 09:12 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
I don't know, but why would the settings be different between a truck and the boat. Perhaps the fuel pump is not delivering enough fuel?
Old 08-13-2008, 12:16 AM
Rep: 10 Posts: 2
I checked the feul pump and seems to be working properly. It seems the angle of attack is much more harsh on this boat when turning sharp then on a normal vehicle on normal roads. I understand though if the feul pump has good pressure but not enough volume, that could be a problem. I'm going to try a high volume electic pump and see if that helps. Thanks.
Old 08-26-2008, 07:43 AM
Rep: 56 Posts: 323
did you get it running yet?
Daggerboard Adjustment Fanie Multihulls 10 05-27-2008 08:56 AM
I think it Will Float ratrace2 Boat Design 12 05-19-2008 09:32 AM
Help pls with Shift Lever adjustment Billy Bones Outboards 3 09-07-2006 06:05 PM
Moth rudder foil trim tab adjustment Benjino Boatbuilding 1 08-29-2006 02:29 PM
Quadrajet Adjustment ChillrMn1 Propulsion 53 06-25-2006 06:27 PM
