Old 03-31-2010, 03:20 PM
Stuff4Toys's Avatar
Stuff4Toys Stuff4Toys is offline
Rep: 14 Posts: 5
Car Engine vs Marineized Engine
Been lurking here a while and see that there are some REAL common sense people on here, THanks for Your Input in advance.
I have an '81 John Allmand that I just love, but the old Ford 351W is showing allot of rust at all the expected seams. Thinking about Modernization and Fuel Economy, I have access to a 2005 Ford Mustang 302 Fuel Injected engine with about 50k miles on it.
I understand the computer issues and the need for a custom CHIP, but what other issues would I run into with a swap like this.
Vlevet Drive 71c 1:1
Bell Housing?
Starter?
Exhaust Manifolds?
TIA
JOhn ><>
http://www.Stuff4Toys.com/ - Marine Electronics
http://www.jmDualPro.com/ - Dual Pro Battery Chargers
http://www.USFlagPro.com/ - Flags, American, Nautical, More ...
Old 03-31-2010, 03:35 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
add spark/backfire for the air cleaner. to the list. And if exhaust manifolds are not on the market the cost for costom is very high. You can buy a complete marine rebuilt of your engine for around 2,500.00 or less.
Old 03-31-2010, 06:03 PM
Rep: 418 Posts: 777
Your fuel injection challenges will start with o2 sensor problems. Marine engines work better with a different cam than the one you have in the 302. Marine engines are built a little looser. It might be better to freshen up the 351. No replacement for displacement!
Old 03-31-2010, 06:08 PM
Stuff4Toys's Avatar
Rep: 14 Posts: 5
Tough part is all the rusted/crusted bolts. I just bought this boat as a project a few weeks ago, and 1 out of 3 bolts are rusted or busted off. I might have to opt for a professionally built long block.
Thanks for helping erase the thought about the 302, however EFI still intrigues me. Maybe I need to convert to MerCruiser or FlagShip.
Old 04-01-2010, 07:12 AM
jonr jonr is offline
Rep: 34 Posts: 246
You could convert any engine to EFI (at some cost). Most interesting (to me) is the Megasquirt stuff.
http://en.wikipedia.org/wiki/MegaSquirt
Old 04-01-2010, 08:37 AM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
Previous Poster is correct about no substitute for displacement. Also make sure you go with a High Torgue cam shaft. Once you get the boat up on plane, the mustang cam will be OK, BUT, I suspect you will not be happy with slow speed acceleration (Hole Shot)
Exhaust manifolds, Starter, Bell Housing are the same. 71C Trans is good with up to about 400 HP.
I have a stroked 302 (327 cu in. ) in my 2000# runabout. Using a 72C Trans, since power and torgue are way above 400HP and 400 lb/ft. Has tremendous Torque, Am able to put my "Entire boat Airborn" from idle speed .
Old 04-01-2010, 03:06 PM
Rep: 418 Posts: 777
Someone will correct me if I'm wrong but most marine EFI units don't use an
o2 senser. There are ways to use one but the trick is keeping it dry. I believe Holley makes a store bought after market unit.
I hear you about the rust. Good foamy penetrant, heat, and patience may be worth trying. You need all the marinization parts, either old or new.
Try lurking around these guys http://www.performanceboats.com/html...splay.php?f=37
They are racing guys, all motor all day. Fresh water drag racing stuff mostly.
The dyno room is the place to go.
Old 04-01-2010, 03:17 PM
Rep: 1493 Posts: 7,447
The car engine has a fuel pump in the fuel tank instead of a sealed one bolted to the block. It is difficult end expensive to convert the whole thing. You can change the camshaft and oil pump on the car engine and convert it to carburated for cheaper/
Old 04-01-2010, 04:31 PM
Carteret Carteret is offline
Rep: 122 Posts: 107
TW is correct. I have had the 302 and the 351W. The 351 has a longer stroke and much better torque.
Old 04-25-2010, 01:40 PM
Stuff4Toys's Avatar
Rep: 14 Posts: 5
Back on this project.
I guess I should have described the boat better.
1981 26' John Allmand
So there is no need for performance or "Planning" ability, this is a 8 - 15 knot boat.
I have not found alot of info on Ford Marine Engines and/or Mods, assuming that the whole world has gone GM, would I be better of going to Mercruiser for a replacement engine?
JOhn ><>
Old 04-25-2010, 02:50 PM
Rep: 122 Posts: 107
I have a 26' Allmand. Been running it for quite a while. Good heavy boat. I put a 6.5 ltr diesel in it back in 2000.
Old 04-25-2010, 02:56 PM
Stuff4Toys's Avatar
Rep: 14 Posts: 5
Hey that looks just like mine. I'll bet that diesel gets good mileage.
What gear ratio are you using? Top RPM?
What did that set you back?
JOhn ><>
Old 04-25-2010, 05:22 PM
Rep: 122 Posts: 107
Same velvet drive as you 71c, 1 inch shaft turning a 14 x 13 cupped wheel.
The 6.5 turns up to 3400. I cruise at 2700. Burns between 3 - 5 gallons an hour.
Been using it for 10 years and picked the engine up used. Marine power Inc. out of Louisiana sold it to a guy up here who put it in a Grand Banks style trawler. He didn't like it, they yanked it and I offered Marine power 4 grand and they let me take it. I have saved a bunch in gas in ten years. I used to burn 12 to 14 gallons an hour. I like the simplicity and safety of a diesel. The reliability is worth the extra effort and money.
Car engine vs. outboard F.H.B. Gas Engines 58 07-11-2010 07:31 AM
NEED ADVICE!!(outboard to inboard 1.5 car engine ) Sceptre Inboards 7 05-29-2010 12:59 PM
Honda Car Engine as an Inboard? nukejr Gas Engines 3 10-01-2007 05:05 PM
How good those diesel engine marinized from car? taobsu Diesel Engines 10 05-20-2006 02:32 PM
