| can't get past 2600 rpms 2001 shamrock 420 hrs 5.7 pleasurecraft. Checked compress,spark ,dist and changed ecu at manufact suggestion after test indicated all electronic systems ok. Where do i go from here? |
| Sounds like all there's left to check is Fuel - Fuel Injection, perhaps Fuel pressure? |
| Max 2600 rpms Thanks but presure is almost 15 lbs at the injecter rail. Computer tells us motor using 1gal at 1000, 7gal /hr at 2000, and 15 gal /hr at 2600 rpms plowing trying to get up on plane. Normal to burn 10- 12 gal/hr cruising. I'm stimied so is pleasure craft and mechanic. Any other ideas would be appreciated, Mahalo , Molokai Bro |
| dose the engine miss or cut out at higher rpms? sure you have checked your air intakesand cleaned rakoars and or filters for fuel problems,,,,,,,,water,if that dont help I would go back to manufactureand put it on the computer could be a chip or sensor problem |
| longline45 Runs without any miss or any indication until it hits 2600 rpm and then it fells like a governor kicks in . put throtel all the way down and no change.Have changed filters both air and fuel. didn't check injectors as computer indicated it was going thru a lot of fuel? What are rakors? Appreciate any other help, |
| raykors ..spelling ? are fuel filters that catch water in diesle engines, ,,sorry for not being to much help. |
| dont know if you have em but vacuum lines could be collapsing under strain at higher rpms? |
What has changed since then? Did it slowly get worse or just stop running over 2600 all of a sudden?
__________________ Proud supporter of The Far Kurnell Cat Racing Team I have not failed. I've just found 10,000 ways that won't work. - Thomas A. Edison |
| Your exhaust system checked ?Do this engine have RPM kill switch ?set properly? |
| Molokai Bro Aloha and a big mahala to all how helped. The boat had sat during the heat for 5 months. Water must have gotten past the 2 fuel filters and corrodided the injectors. so bad that first rail injejtors when disconnected individual didn't change idel at all. corrision even under o ring on alum rail. openings on 2 almost closed at opening don't see how it even ran not alone how it ran smooth.Mechanic said that's the last thing they would check. Verifing injector elecricaly then visually a lot quicker and less expensive than changing the ecm as reccommended by Pleasure Craft and the Marine service center. Hope this might help someone else |
| Glad you found it, sounds very fixable. I just wanted to add to Longliner's thoughts. He was suggesting you check the Racor's, and if you don't have them, I think you want to install them. They are water separators with a filter. Dahl is another popular brand, but nowhere near Racor. They'll save you this aggravation in the future. Good Luck Mike |
| thanks for keeping us up on it, I was curious,thanks |
| Pressure should be around 39 pounds at the rail
__________________ Gonzo |
| Low RPMs | rpickoff | Propulsion | 16 | 08-31-2005 08:48 AM |
| Low RPMs RESOLVED | rpickoff | Propulsion | 0 | 08-26-2005 07:53 PM |
| A blast from the past | Neal | Boat Design | 2 | 03-02-2005 06:50 AM |
