| Cam Selection 350 Mag ' 87 Am in the process of building an '87 350 Magnum (to replace a freeze damaged heads and block) in a Donzi Z21. In the process of selecting a cam and am looking for some input (I am a "car guy" and not sure about a cam selection for a boat with "wet" exhaust). The engine is basically a stock 2 bolt 350 (non-roller block) and the heads are 882's. The exhaust is straight through the transom and there is a Q-jet on the stock manifold. I am running a Alpha drive with a Power Tech 19P. The boat use to max at ~4,800 RPM with the stock (260HP). Looking to increase to ~300HP. I was wondering what were the specs on the original cam and what cam would be a good fit with these heads? Do not mind a "little" lump in the idle. Planning on staying with the tappets as a roller is too much $$$ for the build and what I think the return would be. Thoughts? |
| Stick with a standard cam and 260HP or less. That already drives the Alpha to its physical limits. With more torque the vertical drive shaft snaps where the upper O-ring groove is. It may not happen straightaway on your 1th trip when you stay near the marina and treat the engine gently because you just assembled it. The usual place for this to happen is far away and the only people you can see are those in your boat.
| The original camshafts were made by Crane. They are readily available.
__________________ Gonzo |
| Original Cam Specs Does anyone know the original cam specs for the '87 350 Mag (Carb)? |
There are other cams Crane/Merc made for 350's and they were used in the 280,300 and 320 no problem at idle but a little better if your boat does over say 55mph These will lift the peak torque and hp up the range a bit. With these there is no other change required in the valve train so its a simple install. Personally I would install roller tip rockers ( cheaper than full rollers) and guide plates and screw in studs for sure. Edelbrok also made the inlet manifold for the merc 280 and 300( which they will sell) it is anodised black so it will survive in sea water. If you want to run WOT all day you will also need an oil cooler.
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| The Mercury number is 431-5943 and the Sierra number is 18-1484. It is the same from the 228GM to the 350GM Magnum and the 5.7 Ski
| SA Sailing Mag sucks | Fanie | Open Discussion: All Things Boats & Boating | 6 | 12-16-2008 05:30 AM |
| Adding RamJet to 350 MAG | Zackman | Sterndrives | 7 | 01-24-2007 11:34 PM |
| COURSE AU LARGE mag now online | brian eiland | Boat Design | 0 | 12-11-2006 11:33 PM |
| Nat'l mag looking for boatbuilders | Boatbuilding | 0 | 03-13-2002 09:00 AM | |
| Nat'l mag looking for boatbuilders | Education | 0 | 03-13-2002 08:59 AM | |
