Old 12-05-2010, 08:16 AM
Rep: 756 Posts: 3,328
Big Gas Engine
We are also motorhome folks and prefer bus conversions to "sticks and staples.
The current project is a 36 ft bus getting re engined with a series 50 DD run at 320hp.
To lower the cost of parts like a bellhousing a donor ser 50 was purchased.
This is a "natural gas" engine that is a duplicate of the diesel, but its NOT a diesel!!!
The engine has ignitors and spark plugs where the injectors would be , and the same (mostly) electronic simply fires the spark.
With a big fuel injection mounted on the unit it should be a really strong 300-400 hp with 1400 ft lbs of torque .
Gasoline is far easier to live with for a 100 hour a year toy, but with an engine weight of about a ton (2000lbs) the question comes,
What do I do with it? It will be silent as any car engine.
Its almost 4 ft tall, so its not going into a very small boat.
Ideas???
FF
How big an engine is too big for my motor sailer rileyatsea Inboards 6 12-21-2010 07:09 PM
Chrysler LM318 gas engine problems duane Gas Engines 1 07-06-2010 12:22 PM
Small inboard gas engine dskira Gas Engines 31 11-09-2009 08:55 AM
How can I make a gas engine run on WVO? confused Gas Engines 86 07-09-2009 12:33 PM
Relative gas consumption from 2 vs 1 engine SamSam Propulsion 2 08-17-2007 12:36 PM
