Old 09-07-2009, 06:40 PM
johnnyman42 johnnyman42 is offline
'83 liberator merc 260
please forgive me im new at this but im having trouble hoping i could get pointed in the right direction I had boat out and im wide open and i had the trim up a little went into a sharp turn and lost all power so im thinking oh no i hit some mud or something but not sure so i through it in neutral and checked to see if prop was still there it was so i trim down for take off and drop in gear and nothing the prop does not move I know your thinking like i was the hub but then i look in the engine compartmant and im taking on water from the transom when i get home i ran a hose by the transom note that the engine was not running i was just squirting it around to see where it was leaking for sure on the back of the out drive and i still could see water coming through the rubber hoses i think there called bellows any way then i checked the oil and milk shake please anyone with any ideas that willn point me in the right direction it would be much appreciated
Old 09-07-2009, 07:08 PM
stimulous check stimulous check is offline
Rep: 10 Posts: 14
You're talking about the gear lube in the drive, not the oil in the engine, right?
You need to pull the outdrive off and closely inspect the bellows and ujoints.
I've heard of people breaking gimbal rings and the ujoints breaking through the bellows - if you were trimmed way up and now the bellows have a hole... I would have though you would really hear that though.
Mercruiser 260 Overheating Griff Gas Engines 12 12-10-2009 01:51 AM
Transom Recore Liberator 261 Tips welcome linear Boatbuilding 2 07-19-2009 11:45 AM
Mercruiser 260 Well Craft Walt29 Gas Engines 1 07-14-2009 11:09 AM
steam thru prop hub merc 260? Marshall1 Sterndrives 3 06-12-2007 09:35 PM
Formula 255 Liberator Prater Powerboats 9 04-16-2006 05:49 PM
