Old 07-10-2011, 10:03 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Ok I stand corrected but please explain how a bottle of ---what can fix the valves in a lifter (follower in English)
In English language ,--If its knackered its knackered.
Old 07-10-2011, 11:40 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
I have a sneaky feeling that you know exactly how a hydraulic lifter works Frosty, however,the small hole in the side of the Rover lifters blocked very easily and sticking noisy lifters were a problem the 3.5 was a lowish oil pressure engine anyway ,particularly the SD1 version on which they changed the oil pump to high volume lower pressure. Stop leak was effective in keeping the oil flowing from the gallery in the crankcase into the lifter and pressurising it. The information came from a friend who was foreman at a Rover main dealer in the 1970's so I imagine it filtered down from BL but I can't be sure. Regarding your problem of tingling in another thread, I used to have the same thing happen when I touched the wife ,seems to have cured itself now though.
Old 07-10-2011, 05:02 PM
marragtop marragtop is offline
Rep: 10 Posts: 2
Thanks for the replies. Just to clarify... this is a stock 2005 marine 5.7 Vortec (carbuerated) motor with hydraulic roller lifters. When I stated that the lifters were not compressing, that was with the intake off, and certainly not running. I don't want to put any sort of 'snake oil' in this, so I've ordered a new set of CompCam lifters. I'm also going to change the oil back to Quicksilver 25-40w and will run it with the covers off to make sure I'm getting ample oil supply.
Suggestions are appreciated.
Mike
Old 07-10-2011, 07:20 PM
Rep: 3125 Posts: 9,399
This generation of small block doesn't have the design flaws of the BL products. In fact, the replacement pump and lifters for those engine are superseded by lifters with bigger bleed holes and the pumps have higher pressures.
I wouldn't spend the extra money on a set of Comp Cam lifters. Just pick up GM Performance part lifters (809-12499225), I just bought a set a month or so ago for a third of the price of Crain, Comp, Edelbrock, etc.
Also paying a premium for Mercury oil isn't necessary either. A generic 20w50 will suit you fine at half the price. Who do you think makes the oil for Mercury and for Auto Zone, Pep Boys, etc.? These are just "re-badged" products that cost more for the same thing. In other words, Wal-Mart brand 20w50 is exactly the same as Quaker State 20w50.
Lastly why buy lifters for something when you don't know if they're bad? I'm telling you check the valve train, you'll probably find some bent valves or push rods. Doing the diagnostics before you order parts is the wise course of action.
Roller furling boom Stumble Sailboats 6 06-26-2011 01:50 AM
Head sail roller furling kenJ Sailboats 1 09-28-2010 12:43 PM
Is there a difference in quality between roller furler mfg? ecflyer Sailboats 10 11-20-2009 12:56 AM
Roller reefing boom Steve W Boat Design 8 04-11-2009 04:31 AM
Roller reefing/furling boom Steve W Boat Design 0 09-20-2008 10:07 AM
