Old 06-29-2008, 12:47 PM
77taylor 77taylor is offline
Rep: 10 Posts: 5
455 water in oil
Hello, i bought a 77 taylor with a 455 olds, freshly rebuilt with an oversize cam. 100 hrs and its was getting water in the oil, i replaced all the gaskets and no help. I assumed a cracked block. So i purchased a second motor and i now have the very same problem. I have a berkeley jet drive no water pump on the motor. Could it be my water jackets? I connected the water jackets cooling lines together and hooked up the hose. no sign of water out the exhaust? im stumped the guy i bought the motor off of swears up and down theirs no problem with the new motor.
Old 07-04-2008, 12:59 AM
mr curious's Avatar
mr curious mr curious is offline
gunkholer supreme
Rep: 20 Posts: 94
cracked head maybe
Old 07-05-2008, 08:02 AM
Rep: 10 Posts: 5
no i dont think so the motor was just rebuilt, and besides the last motor had the same problem. Can i have that bad of luck?
Old 07-05-2008, 08:54 AM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
I believe, if your cam shaft has too much overlap with stock type exhaust manifolds, it is posible to get water into the motor thru the Exhaust valves.
See :
http://findarticles.com/p/articles/m..._8/ai_96379178
Old 07-07-2008, 10:48 PM
Rep: 10 Posts: 5
The last time i took it out i gained about half a quart in 30 minutes.
Old 05-22-2009, 10:49 PM
Markster Markster is offline
Rep: 10 Posts: 2
While you probably solved the water in the oil issue by now, I had the same problem. Had the head magnefluxed and was told no cracks. Turned out it was a cracked head. Found the crack by removing the valve covers, taking off the water lines where the hose goes into the riser and then crimping and clamping the water lines so as to stop the water from exiting the engine. Then connected a water hose to the engine (like I was going to run it on land), and with the engine off I turned on the hose. Nice 80 lb or so pressure test. Leak showed up right away, dead center on one of the heads. Would not have seen the crack without the water test.
Water in the oil also caused a spun bearing earlier.
Old 06-02-2009, 04:06 PM
ABBOTTCRAFT ABBOTTCRAFT is offline
Rep: 10 Posts: 4
My money's on an "Intake Leak"...It happens alot.. Are you useing the rubber end gaskets supplied in the gasket set... If so, that's the problem...Throw them away & use RTV Silicon on the intake ends & alittle around the water ports..Problem solved..........
Old 06-03-2009, 12:27 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
Well this is easy,--its probably some bits that were on the old engine and now on the new. Logical my dear watson.
Old 06-03-2009, 12:32 PM
Rep: 1397 Posts: 7,215
A larger than factory cam will almost surely make water get back into the exhaust. A crossover pipe from one riser to the other helps.
Old 06-03-2009, 01:04 PM
Frosty's Avatar
But hes getting water in oil!!!
Water in the cylinders due to reversion would cause a misfire and stop it, would'nt you agree?
Quote --a quart in 30 minutes.
Old 06-03-2009, 01:11 PM
The overlap causes suction mainly at lower speeds and reverses the flow at the risers. It is like having a head gasket leak or a cracked head. Also, when the engine stops it sucks water back. The GM8.2 had the same problem even with factory cam. The fix was a pipe between the right and left exhaust.
Old 06-03-2009, 01:16 PM
Frosty's Avatar
I can understand the reversion being helped by a cross over ( common on motorcycles too)
But hes getting lots into the oil.
I'lle go for the inlet manifold too.
Old 06-03-2009, 01:53 PM
Rangerspeedboat Rangerspeedboat is offline
Rep: 17 Posts: 120
There could also be a seal or a fitting inside the engine leaking oil. This happened to one of our engines, the rebuilder just didnt tighten the fitting.
Old 12-06-2009, 05:24 PM
455Rocket123 455Rocket123 is offline
Cracked heads Or Intake gaskets The valley pan Set Does Not Come With The Intake gaskets You can Get Them On Summit for 12 Bucks I Went Through This With My 455 10 Qts Of Oil And 3 valley Pans later I Got The Problem
Old 12-08-2009, 08:35 PM
mreoe4sure mreoe4sure is offline
who me
Rep: 24 Posts: 13
Do you have a presure reducing valve on the berkley pump, Many times these problems water in oil can be traced to a lack of one. The pump will put out around 100 psi and will cause intake gasket, front cover gaskets ( where water pump is removed) to leak. These gaskets are not made for this kind of presure. They are made to withstand around 20 psi, and if there is any surfaces that are not straight it will cause a leak. Hope I have not upset anyone with my 2cents Steve
Water in the Engine and oil krisnowicki Inboards 7 12-03-2007 08:01 PM
good olds water in the oil 455 junkie Boat Design 2 10-04-2006 07:52 AM
water in oil Notayaht Inboards 2 07-27-2006 03:29 PM
Water in Oil Problem ScCoghill Propulsion 3 06-05-2005 02:09 AM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 06:43 PM
