Old 08-22-2010, 12:47 PM
El Sea El Sea is offline
Rep: 36 Posts: 55
My money is fuel related...
El Sea,
"Suckin sludge & Havin a Gas"
Old 08-23-2010, 12:30 PM
YvonneDee YvonneDee is offline
Rep: 10 Posts: 10
Spoke to soon. Ran great................zing zing zing goes the starter. ERRRR. Taking boat to another marina.
Old 08-27-2010, 08:07 AM
frank smith frank smith is offline
Rep: 154 Posts: 672
Timing , maybe cam chain, wiring in the wrong order, distributor in wrong .
Old 08-27-2010, 08:55 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
I had a similar problem with my '87 VP AQ271A (GM 350). Had to rebuilt distributor, replace the electronic ign module in the distributor, new rev limiter, coil and reset timing. Also had low vacuum at the carb (not the intake manifold) problem was wrong gasket between carb & intake.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 09-01-2010, 08:34 PM
Rep: 10 Posts: 10
OK replaced starter!! Runs very well. Is it normal for there to be smoke upon acceleration? It is white/gray? It freaked me out!! Thanks.
Old 09-02-2010, 06:26 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
23 years old, neglected, serviced by idiots... and it just spits out some gray smoke. You are one lucky lady!
Old 09-02-2010, 06:50 AM
Rep: 578 Posts: 615
Could be valve seals. Does it go away when it warms up?
Old 09-02-2010, 08:23 AM
Ramius41 Ramius41 is offline
Rep: 10 Posts: 30
The smoke could be from the water injected in the exhaust manifold....for cooling....it should have that...also check the oil...make sure its not milky looking...like cream in your coffee...
Old 09-02-2010, 10:09 AM
Rep: 10 Posts: 10
350 V8 OMC Chevy Engine
I did check oil its clean. ODK love your humor! The smoke occurs when accelerating to plane out and then dissipates. Every time I get in the boat I need a sedative I love this boat (Celebrity) it rides nice. Needs TLC and at this juncture I refuse to stop until shes looking like new!!
  #25
Old 09-07-2010, 12:12 PM
Rep: 10 Posts: 10
Lucky I think not! Boat started to klunk in reverse. Forward and neutral works ok
Has new throttle cable. Can I run it like this until boat comes out in 3 weeks for winter. I appreciate your in put. Thanks
Yvonne
  #26
Old 09-07-2010, 01:37 PM
CDK's Avatar
CDK CDK is offline
retired engineer
Klunk as in jumping in and out of gear?
Time to check the shift cable, it may need some adjustment and a few drops of oil. Avoid the reverse as much as possible, when inevitable use near idle rpm only.
That and some bad weather will help the boat to survive these last 3 weeks.
  #27
Old 09-08-2010, 08:13 AM
Rep: 10 Posts: 10
Thanks for getting back to me. Intermittent clunk in reverse.Reverse worked. So I avoided using the reverse but had to at gas pumps. Now there is no reverse and it started clunking in forward when first put into gear then goes away in about 10 seconds.( just like the reverse) So the boat has not moved. Taking out this week. I have so much money in this boat. The marina that had the boat stated that they tightened the throttle cable? Its going to another marina for repair this time. Thanks Yvonne
OMC 350 dying JerryIkemire Gas Engines 5 07-09-2010 07:52 AM
looking for thermostat housing 350 Chevy OMC TEE Propulsion 1 05-10-2010 12:18 PM
454 chevy engine fritzer Gas Engines 3 07-08-2008 10:21 PM
Original 24' Sea Bird Hull! 351 ford 350 chevy boatguy64 Marketplace 0 03-03-2008 01:58 PM
Chevy Engine Model crenshaw Boat Design 2 01-19-2006 01:05 PM
