Old 01-03-2007, 09:48 PM
bonanzaman bonanzaman is offline
Rep: 10 Posts: 4
233HP Mercruiser re-Power
Greetings, oh great marine engine gurus! I am most likely faced with re-powering my 76 Century straight outboard due to some dumb stick forgetting to winterize his new toy, and most likely cracking the block! (Mercruiser 351/233HP). If it turns out the block is indeed cracked, (I'll know in the spring when we fire her up!) can I use anything from the existing accessories, manifolds, risers, ect, if I want to upgrade to a big-block engine? In my place, if you wanted about 300hp what engine would be easiest to replace the old 233hp with??
Thanks for any suggestions!
*Forgot to mention, I've a bit of experience building auto engines, but new to marine!
Old 01-03-2007, 10:58 PM
stonebreaker stonebreaker is offline
Rep: 42 Posts: 438
Did you say 351? Is that a ford engine?
Stonebreaker
Ph.D in Redneck Engineering - Piling it higher and Deeper.
Old 01-04-2007, 12:08 AM
Rep: 10 Posts: 4
Well, that is the displacement shown in the Ops manual that came with the boat. It is a Mercruiser "Model 233" . The 351 displacement tells me it is a Ford-Based engine. Still trying to figure out this marine nomenclature!
Old 01-04-2007, 12:28 AM
Rep: 42 Posts: 438
Well, why not just replace it with a 351 crate motor? Shouldn't be too hard to find a 300 hp small block.
Stonebreaker
Old 01-04-2007, 01:18 PM
Rep: 10 Posts: 4
233 Merc repower
Yes, that would be a "long block" w/heads right? Any ideas where to look?
Thanks!
Old 01-04-2007, 04:36 PM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
Yes it is a 351 Ford. Go to any reputable engine rebuilder and get a late model, 93 - 96 truck short block (roller cam engine ) add ported and polished iron heads and a 4 b carb lfor an easy 350 HP and 400+ ft-lb torque. The stock truck roller cam will work great.
If you want more, add some good flowing Alum Hds for another 100 horses and 50 ft-lb torque. ALL your existing marine stuff will bolt right on. Just be sure to use marine type gaskets.
Old 01-04-2007, 05:26 PM
Rep: 10 Posts: 4
Cool, that's what I was hoping, that makes it a do-able project for me!
Thanks for that good news!!
Old 01-04-2007, 09:17 PM
Rep: 1397 Posts: 7,215
We sell 351 base engines for about $3700.00. They are new. A 351 GT-40 MPI complete is $7,000.00.
mercruiser alpha one 1.84 to 1.98 hlaten Sterndrives 2 07-24-2006 12:17 PM
More power from a Mercruiser 165 Jenerator Propulsion 6 11-18-2005 08:14 PM
Sail power and horse power? kjell Motorsailers 12 09-03-2005 04:20 AM
Mercruiser exhaust cptmclark Propulsion 0 07-31-2005 10:19 PM
4.3l Vs 4.3mpi Mercruiser ACHALAT Propulsion 2 12-18-2004 09:16 PM
