| 1989 4.3L - upgrade to 5.7 or newer 4.3L questions I have a 1989 Ebbtide Rivera with a 4.3L engine with a cracked block . I would prefer to upgrade to a 5.7L and if that is not possible, to upgrade to a newer 4.3L Vortec long block. I believe I have enough room for the 5.7L - however anyone know the difference in length of the block? Since the boat has fixed motor mounts, does the 5.7L block have mount locations anywhere near the 4.3L ? And if the 5.7L is not possible, anyone know of issues replacing a 89 4.3L with a newer vortec - that way I can have a smoother engine and there seem to be some upgrade options with 4bbl manifolds available for the vortec engines. Thanks for any suggestions, Pat |
| This site will show you all necessary dimensions of the GM engines. http://www.gm.com/experience/technol...ne_engines.jsp No problem changing older 4.3 to newer 4.3 though I cannot say if GM changed the motor mounts--it's doutful in my opinion. Newer ones come with fuel injection. Check out Michigan motorz http://www.michiganmotorz.com/marine...s-c-31_55.html |
| If you change the engine to a 5.7, you will have to re-gear the transmission too.
__________________ Gonzo |
| Hauling a 1989 Bayfield 25 | john w | Sailboats | 0 | 11-20-2008 02:02 PM |
| FYI Common Grounds Newer Stereos | KnottyBuoyz | OnBoard Electronics & Controls | 1 | 04-06-2008 03:47 PM |
| 1989 Ski Supreme | JoJo | Fiberglass and Composite Boat Building | 1 | 10-08-2005 10:28 AM |
| Would like to replace 1989 5.7 OMC - Help! | kakidsdsu | Boat Design | 3 | 05-07-2005 11:14 PM |
| a newer involved in maxsurf | jennifer | Software | 4 | 07-06-2004 08:28 AM |
