Old 08-02-2010, 07:55 AM
DOSGATOS DOSGATOS is offline
Rep: 10 Posts: 2
1988 Luhrs
Hello: I Have A 1988 Luhrs, Alura 30, It Has A 350chevy,4bbl And 71c Velvet Drive. My Problem Is That It All Of A Sudden Started Slowing In Rpm And Will Not Go Over 3000rpm, The Engine Starts And Runs Fine, Revs Up To 4700rpm No Problem,but When You Put In Gear, It Wines Pretty Loud And Will Not Go Over 3000rpm, Question, Will The Trans Cause This Problem With A Damper Affect Or Slipping Clutches? Help Please. I Have Changed Everything On The Motor Thinking That It Was The Motor??? Dosgatos
Old 08-03-2010, 06:25 AM
kenJ kenJ is offline
Rep: 56 Posts: 333
A fouled prop or a line wrapped around the shaft? Is this an all of a sudden problem or has it been sneaking up on you? Does the prop shaft turn freely by hand? Have you checked the oil level in the trans?
Old 08-03-2010, 07:59 AM
Rep: 10 Posts: 2
Thanks, For The Reply, Yes, I Thought Of That And Went Down And Cleaned The Bottom, Shaft And Prop, No Difference, The Prop Turns Free From Under Water With Very Little Drag, Just Enough To Be The Shaft Seal. It Always Stops Going Any More Than About3000rpm Every Time I Try It. Will The Trans Cause This Problem?
Old 08-04-2010, 06:00 PM
Bglad Bglad is offline
Rep: 67 Posts: 156
Have you checked to see that the secondaries on the carburetor are opening? 3000 rpms is usually about where they kick in.
Luhrs 28 with single 454 V-drive 7228sedan Inboards 20 12-16-2009 06:54 PM
What should I put in a 25' Luhrs flybridge? mongo75 Diesel Engines 7 10-12-2009 09:15 PM
35 luhrs alura fish1860 Powerboats 3 03-12-2007 12:50 AM
Question on Luhrs Allura 35 firepiper Boat Design 0 08-08-2006 10:27 PM
Michael Peters - Luhrs 78 Willallison Powerboats 2 08-18-2003 06:10 PM
