Go Back   Boat Design Forums > Community > Open Discussion: All Things Boats & Boating > Forum Questions and Suggestions
Old 02-25-2009, 09:22 AM
ned L ned L is offline
Rep: 105 Posts: 44
Understanding 'rep points' question.
I started visiting here regularly about four months ago now & just caught on to what the 'rep points' are, and was surprised to see that I am at a -5. When I looked to find out why I was equally surprised to see that I was given negative points for suggesting that a new member might find a more knowledge and comprehensive answer on a different web site. (In the two and a half weeks since then there have been only three other replies to that person’s question, and none of the replies answered his question, so I still believer that my referral was good advise.)
I have to say that I don't really understand the logic for a negative hit when good direction to other helpful references is given. Is it a policy of this site not to refer people to other places even if the answer cannot be found here? Just wondering.
Old 02-25-2009, 10:05 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
The rep points are given or taken by individuals, and not any policy. Watch. I'll fix you right up.
Old 02-25-2009, 10:27 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,519
Hmmmm well Ille give you a tip, usually you dont know who dun it but if you were hit by 15 points then its some one with a reasonable amount of points them self. The more you have the more you have clout power
Its a very un popular system and is hated by all but the admin. It has caused all sorts of problems but to date as I know of cured none.
Ive sent you a few. You did the right thing.
Old 02-25-2009, 03:48 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
I made up my mind NEVER EVER TO GIVE neg points, and as these two say it is really unpopular, and often has little to do with your skills advice or knowledge. there is a lot of poor advice given but the drill is ignore it and IF someone still posts drivel, just put im on ignore
Old 02-25-2009, 04:38 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
ned L, It seems that the "gutless cretin" has struck again (or are they breeding in hyperspace)... My policy is to post affirmative ONLY and give, as a way of saying "thank You" in a constructive way.... Negative points just show the petulant immaturity of the "taker" and their sad mental state as it is usually done anonymously - one has to insert (type in) your "avatar name", as it is not automatic as in open posts and PM's.
I hope you grow to enjoy participation in your areas of interest as there is ample space for all topics - just keep the subject thread in the appropriate grouping as some seem to object to forms of piracy and cross polination
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 02-26-2009, 10:36 AM
Rep: 105 Posts: 44
Thanks for the replies, I guess these 'rep points' are a bit of a hot button & I now understand why. I just thought it quite odd to be in negative numbers for directing someone to a good source for their answer. (I was also a bit surprised at who I think did it (looking @ the time stamp) as, based on his replies, he does know what he is talking about).
I won't be doing a lot of posting here as I generally comment only on what I know & don't see a need to duplicate answers to much. However, if anyone needs to know anything about the boats and boatbuilding on the New Jersey shore (esp. lapstrake) I'll be here (There is a hundred+ year history of probably more pleasure boat builders there than in just about any other equally sized area in the country.)
Old 02-26-2009, 11:13 AM
Frosty's Avatar
Ned dont be put off by some negative cretin, we have all had to put up with this admin decision, as said no one likes it.
It is hard however to soldier forward under fire for free but we are for some strange reason expected to do so. ( some comments on that one I expect)
Just write what you want and to hell with it.
It has infact had the opposite effect to what was thought to be the result. In other words I think people have become careless in there replies expecting deduction were non was called for or was necessary due to mis understanding of the system as was yourself.
Some seem to think that disagreement is cause for deduction, usually beginers. It is however for inappropriate behavour and certainly not disagreement which is normal in every day discussion
Old 02-26-2009, 11:25 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
Just ignore the point system, your number will grow over time.
I don't play the game myself, if I like something I might send a PM, or mention it in the thread.
That's just me though.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 02-27-2009, 01:39 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
'tis a totally rediclious system that drives some to distraction, best left to itself, it does cause some problems at times when a certain well know unmarked gutless wonder - actually the main one got banned but he's back, but at the moment is being clever (or as clever as he thinks he can be) started giving negative points out to many people - it proved one thing tho' (it wasn't intended to) that the system didn't work!!
ignore it - if you can - Kach is right
Old 03-01-2009, 10:49 AM
hansp77 hansp77 is offline
Rep: 200 Posts: 691
666 rep points for the walrus- are you sure those aren't upside down horns mate
Old 03-01-2009, 03:25 PM
masalai
another option is to "vent your spleen" in a thread created for that purpose.... see - - - http://www.boatdesign.net/forums/ope...-21157-74.html in particular, post 1103 and 1104 where some noxious weed gave me some ANONYMOUS negative from a post of about 18 months ago in a long dead thread???? so what the F did I say wrong?
Old 03-01-2009, 03:40 PM
Previous Member
Rep: 0 Posts: 0
you are SUPRISED?just your being here rattles a lot of us, because in 5500 posts you have NOTHING to cintribute abt boating, and I would be suprised if you had ever owned a stock or a business, yet you continue copy, past, rave, day after day, so there you are. You have me on IGGY, great, bet you read this though)
Old 03-02-2009, 02:05 AM
masalai
ned L, I see donations have been flooding in, this has to be a record, 20 posts and 105 rep points well done... - - - That demonstrates the way things should happen, support if you like it and sit quietly if you dont - this world could do with less antagonism towards others.... and more support, sympathy, understanding and friendly attitude....
Whoosh, behave.....
Old 03-12-2009, 03:09 AM
Previous Member
Rep: 0 Posts: 0
Whoosh, behave.....
also it shud reflect upon knowledge of boats and this FORUM NOT THINGS LIKE THE FINANCIAL STATE OF the world, not racism, just boats, knowledge of them, knowledge of weather, knowledge of skills --- so lets all push a real master, sailer, engineer, mariner thru the 1000 Guillermo
Old 03-12-2009, 07:17 PM
masalai
There are 24,468 threads and only a few not specifically and directly related to boats - if you don't like it read something else or better still go back to Europe and build your canal barge (oops sorry that was Lazy Jacks and you saw him buried?) you seem to have an Australian internet address the same as LJ's how come?
Rhino Question about Control Points and Degrees CET Software 4 11-19-2008 07:13 PM
How to delete files in your gallery, forum rep points, forum attachment sizes MikeJohns Forum Questions and Suggestions 10 08-18-2007 07:28 PM
Mounting 'rep' points Bergalia Open Discussion: All Things Boats & Boating 15 06-07-2007 07:15 PM
Rep Points re: westlawn thread Frosty Forum Questions and Suggestions 3 01-07-2007 09:52 PM
Understanding O/B HP ? gerard baladi Powerboats 12 05-20-2005 10:46 PM
