  #31
Old 11-13-2011, 06:38 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
OK, you want a carbon rudder. Keep in mind that there indeed are some pitfalls.
In tension, there usually is no problem. In compression, the strength is about half of the strength in tension. This is true for both glass and carbon, so "no big deal" you would think. Then again, the carbon you plan to use will be less than the amount of glass, so your laminate will be thinner. Your thin laminate will be more prone to "skin buckling" which you could prevent in all sorts of smart ways, like making a "mini sandwich" of the skin, or just use a higher density foam sandwich, which will support the thin laminate more.
What do your rudder pintles look like? I built lightweight carbon rudders long time ago, and at one point I reversed the pintles, as the rudder pushed upwards considerably.
All in all, at this moment I feel that the most effective way to build a rudder, is to mimic the design of an aircraft wing, or a windmill blade. Which basicly means a sturdy spar, which can handle the bending load, and a fairly lightweight "fairing" around it, strong enough for local loads from steering.
That is, if weight is the critical factor, not labour...
About the vinylester / epoxy / infusion epoxy comparison: do not stare blind on their properties, and do not get trapped into the pitfall of always aiming for the technological optimal solution. There is no use spending 20% more to increase properties 1%, especially if you do not need that 1%.
Look at all the crap that is floating around, mostly 30+ years, with constructions and materials that give you a terrible headache. Your product is already so much more advanced. Make it work, produce it in larger quantities, and sell it. If you are not a sales-person, get someone else to sell it for you.
  #32
Old 11-13-2011, 01:50 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
Hmm.. ok, now how about spars & tubes?
With these its all about weight/strength.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
  #33
Old 11-13-2011, 10:44 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Originally Posted by Herman View Post
Over here it is basicly the same, although a lot of semi-iso gelcoat is used, for various projects. For boats iso-npg is recommended, but many projects do not call for such a gelcoat. (interior work, etc). I presume your story above is targeted at the marine industry. Do you also serve other industries?
There were some ISO-ORTHO blends around, but they were phased out even in the low cost interior parts.
At one time the marine market was about 30% of my sales, but in recent times the economy has taken its toll on that market and it's been reduced a great deal.
  #34
Old 11-14-2011, 01:53 AM
Herman's Avatar
Resininfusion.info
Spars and high-tech tubes (there are plenty of low-tech ones) in general are made with carbon and epoxy. Which epoxy? Depends on the process used.
There are very nice prepreg resins, very nice infusion resins, but also very nice pultrusion resins. In a price range from some 6 euro / kg up to 30 euro / kg.
It is all about not over-specifying, and choosing what fits your production systems.
ondarvr. About same here. Although the iso-ortho blends are still big here, for various (non marine) parts. Our biggest sales come from the infrastructure and building industry, pipes and silos, and all kind of general purpose stuff.
vinylester vs epoxy adamfocht Fiberglass and Composite Boat Building 7 01-03-2007 06:45 PM
Can I substitute vinylester for epoxy? Stephen Ditmore Materials 7 12-19-2006 02:23 AM
Vinylester over epoxy... NO !!! Capt. Chris Materials 3 09-25-2005 12:12 AM
Polyester / Vinylester over Epoxy? Capt. Chris Materials 11 09-15-2005 05:37 AM
Vinylester / Epoxy miguel_noe@yahoo.com Materials 1 08-11-2003 01:18 PM
