Old 01-09-2009, 03:25 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 338
Wormholes in infusion?
We've run into something that's giving us fits. Wormholes in the infusion. We are making molds using infusion and we are seeing where small air bubbles near the gelcoat are causing little gelcoat breakouts.
What can be done to minimize air bubbles in infused parts? Where do they come from? It looks like perhaps the resin is boiling when its going into the drystack?
Any hints pointers etc?
Many thanks in advance!
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 01-09-2009, 03:51 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Polyester or epoxy? What laminate? Infusion pressure? Infusion height?
-take care of the right gelcoat thickness (and use a gauge to check this on several places)
-dry your glass
-degass your resin
-get your plug airtight, same for the bag. Test this!
-use a good quality bag. Not everything on the market is suitable.
-experiment with the first layer, that goes against the gelcoat. No unifilo please.
-hand laminate a skin coat (vinylester). Use peelply to get a good bond.
Old 01-09-2009, 04:34 PM
MarboMan's Avatar
MarboMan MarboMan is offline
Rep: 10 Posts: 12
Styrene gets excited under vacuum.
Experiment and see what the bubbling point is of your resin. See how much you can draw on a clear jar with some resin in it before you see the little bubbles forming.
Old 01-10-2009, 03:17 AM
jim lee's Avatar
Rep: 217 Posts: 338
Vinyl ester resin,
As much vacuum as we can pull around 28 1/4 in Hg.
An entire array of laminates,
all small parts from 9' x 9' to about 3" x 2".
We've been doing a lot of experimentation trying to improve our mold building quality. Surface print-through and dimensional stability. (Reduce warping) This worm hole deal was unexpected.
I was thinking about trying degassing the resin. We just got a degassing chamber but have not yet set it up. My fear was that the styrene was boiling off. If that's the case, does this limit the vacuum we can pull?
On our deck mold, the plan is to use a skin coat. But, isn't that just kinda' hiding the problem? The bubbles will not break through the gel coat so much, but they will still be in there.
What does gelcoat thickness have to do with bubbles in the laminate?
The glass is in a heated shop, so I'm thinking its pretty dry.
Thanks again for your ideas.
-jim lee
J/35 No Tomorrows
Old 01-10-2009, 04:27 AM
Herman's Avatar
Resininfusion.info
Do a test with your glass: Take a small piece, weigh it, then put it in an oven, and weigh it again. This is the only way to tell. YOUR shop might be heated, but where is the glass coming from?
Gelcoat thickness: If the gelcoat is thin, and might have some porosity, and the plug is not 100% leak free, then you might pull some air. Slowly, so not visible on top.
Try degassing. Indeed, styrene might boil at 60% vacuum, but still you might take advantage of it.
About your vacuum level during infusion: try infusion at a lower vacuum level. Say 70-80%. Yes, this is above boiling point for styrene, but the pressure drop at the resin front is dramatic. You might notice some boiling at the front, but that is not critical. However, after completing the infusion, the pressure spreads, and then it might be the case that you are boiling out the styrene at some spots. Your high vacuum level might induce that.
About skin coat: Yes, partly hiding, but also partly vacuum integrity. And suface quality might improve.
Old 01-13-2009, 08:49 PM
Cobra1 Cobra1 is offline
Rep: 9 Posts: 82
I thought you were suposed to skin it first then do the infusion build up?? Your'e putting this on the gell then trying to infuse it. See if Sparky can help you. http://www.viciousmarine.com . He built the very first infuse boat, so he knows his shiat. Worth a shot or call the manufacturer and explain the issue to them.
By worm holes you could meen aligator as well, maybe. This is caused by the gel being to thin. The styrene will mess with it big time.
Infusion Education ATCSchaefdog Open Discussion: All Things Boats & Boating 1 07-18-2007 12:49 PM
Infusion Help needed ( jestah Fiberglass and Composite Boat Building 5 06-05-2007 11:57 AM
Best Resin for infusion Amon Materials 7 08-18-2006 10:56 AM
Resin infusion Danielsan Fiberglass and Composite Boat Building 28 11-13-2004 05:13 AM
infusion pdesign Materials 1 08-18-2004 10:41 AM
