  #91
Old 08-11-2010, 01:10 PM
CatBuilder CatBuilder is offline
Rep: 1316 Posts: 3,040
Ok, another question:
I've built a shop table and have the plywood on the table. It has a few residual waves in it that I expect to calm down overnight. All in all, it's very much in line now though.
I went down a smooth part with the Bosch planer (no waves) and the planer, on one side of the planer only, left gouges. So... I brought the $99 planer back to Home Depot and got at nice, $180 Makita planer. I think this will solve the planer issue. My planer was junk.
Next, I replaced my cheap angle grinder (10,000RPM) with a new Hitachi 6 speed polisher/sander (looks like an angle grinder). Here's a picture of it:
The Hitachi goes from 0-3400RPM, much more appropriate for sanding.
I haven't tried this sander out yet either, but I have a question about the polisher/sander:
Everyone uses foam sanding pads for these when doing this kind of work. They use it in designer's video, someone on this thread mentioned to use it, etc...
Where can I get the foam sanding pads?!?
I have tried: Home Depot, Lowes, Ace, a small Professional Tool Shop, Fastenal. I spent all day today driving around looking for foam pads to fit this grinder.
It came with a 5/8", course thread arbor. It has no washer you'd normally see to hold the sanding pads on (that's an optional accessory). Any tips on where to find this kind of thing in North Florida or online with instant shipping?
Thanks! Hope to get some plywood done in the next 24 hours.
Kurt Hughes was right about this place.
  #92
Old 08-11-2010, 06:29 PM
david@boatsmith david@boatsmith is offline
Rep: 50 Posts: 85
Merritt Supply or Glue Products both in West Palm Beach sells both the ads and the discs.
Boatsmith Inc
We Build Your Dreams
(561) 744-0855
www.boatsmithfl.com
  #93
Old 08-12-2010, 08:23 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Get some good sandpaper. Most DIY sandpaper is what it says it is: sand on paper. I like the Mirka stuff, both for price and performance.
You might want a backing disc without a central fixation, but with velcro or self adhesive paper.
  #94
Old 08-12-2010, 02:12 PM
All fixed!
The major problem was junk tools. The new Hitachi polisher/grinder works perfectly. It'll even do scarfs on wavy wood, but with a new work bench, the waviness has been cut in half. Thanks for all the advice. Things are going well now.
  #95
All fixed!
  #96
Old 08-12-2010, 02:55 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Glad to hear you're back on track. Must've been pretty frustrating....
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
  #97
Old 08-12-2010, 03:20 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
yeah, good luck with it
  #98
Old 08-12-2010, 11:40 PM
Boston's Avatar
Boston Boston is online now
Rep: 1457 Posts: 3,355
Sounds great. Best of luck. Post a few Picts when u have a chance. Cheers b
I am skeptical of the deniers diatribe
  #99
Old 08-13-2010, 08:43 AM
thill thill is offline
Rep: 25 Posts: 58
Oops. Should have read all the posts before posting.
When I've been in that situation, I found it VERY helpful to sandwich 2x material top and bottom and clamp to keep everything still. The edge of the 2x acts as an edge guide. I've done a lot of good work using this method.
Also, a makita planer is a good one, especially if it has carbide blades. SHALLOW PASSES!
Best wishes on a great finished product!
-TH
The Woodworking Thread Boston Open Discussion: All Things Boats & Boating 3 10-06-2009 04:57 AM
Boat Building 101... Sean Herron Open Discussion: All Things Boats & Boating 7 03-08-2009 06:02 PM
INDUSTRIAL ESPIONAGE 101 - or other... Sean Herron Boat Design 15 01-19-2008 09:29 PM
Marketing 101 KnottyBuoyz Open Discussion: All Things Boats & Boating 2 07-24-2007 02:28 AM
Fiberglass 101 Daidohead Materials 10 01-21-2007 09:45 AM
