| Wooden boat plans conversion Hi everyone, I need some help with some structural enginering. I have plans for a 20 ft boat with an inboard motor in it. The plans show a cold moulded ply design over wooden frames, but I want to use foam and glass sandwhich, as I have some 600 gram double bias e-glass. I was going to use 15 mm foam with one layer of glass on the inside and two layers of glass on the outside. I would use timber for the keelson, chine and gunwhale, plywood over a few frames for the deck, and I would also need some girders I suppose. Do you think that this would be strong enough. Any help with this would be appreciated. Also if you could tell me how many girders or stringers I would need. |
| You are basically asking for a re-design of the boat, which is not a small task. Purchase Dave Gerr's book "The Elements of Boat Strength" to discover both the answers you need and the amount of effort it takes to arrive at them. |
| Wooden boat builders - HELP! | Converted | Wooden Boat Building and Restoration | 7 | 09-20-2006 11:59 PM |
| help where can i find plans for this boat | jetties2003 | Fiberglass and Composite Boat Building | 3 | 04-16-2005 10:18 PM |
| help where can i find plans for this boat | jetties2003 | Boat Design | 3 | 03-15-2005 02:55 PM |
| help where can i find plans for this boat | jetties2003 | Boatbuilding | 0 | 02-27-2005 09:37 PM |
| looking for pontoon boat plans | Corby Morris | Metal Boat Building | 1 | 09-18-2004 04:14 AM |
