Old 06-30-2011, 12:28 PM
Capt Ram Capt Ram is offline
Rep: 10 Posts: 11
will Gelcoat stick to Epoxy
WIll gelcoat stick to epoxy? Im instaling a hatch and need to do a 2 inch strip?
Old 06-30-2011, 12:40 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,054
Gelcoat over Epoxy
BR Teddy
Old 06-30-2011, 12:50 PM
Rep: 10 Posts: 11
thanks!!
Old 07-01-2011, 02:05 AM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
As a gel coat supplier we recommend not using gel coat over epoxy, the bond typically just isn't that good. And while there are ways to improve the bond, why spend more time and money when paint will do a much better job.
Old 07-01-2011, 03:39 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Remember !!!!! Epoxy Will Go Over Polyester And Vinylester !!!
But Polyester And Vinlyester Does Not Stick Over Epoxy !!!!and In Most Cases Will Not Go Hard At All As The Epoxy Kills The Poly And Vinyl Esters !!!
Making beautiful boats is a passion never a chore !
Old 07-02-2011, 08:36 AM
david@boatsmith david@boatsmith is offline
Rep: 50 Posts: 85
We routinely do repairs with poly gelcoat over epoxy. We wash the epoxy with water and then promptly apply the gelcoat. We have not had any problems with this method. Some repairs are 6-7years old now.
Boatsmith Inc
We Build Your Dreams
(561) 744-0855
www.boatsmithfl.com
Old 07-02-2011, 01:25 PM
Rep: 10 Posts: 11
just water, no aceatone?
Old 07-02-2011, 04:54 PM
Rep: 50 Posts: 85
We also wipe with denatured alcohol but the water seems to neutralize the amines in the epoxy. Without the water wash we used to have problems. The amines seem to leech out during the extended curing of the epoxy. We wash with water and then alcohol and then apply the gelcoat. If it is not going to take it will be obvious within a few hours.
Boatsmith Inc
(561) 744-0855
www.boatsmithfl.com
Old 07-02-2011, 10:46 PM
Rep: 10 Posts: 11
Thanks David, im sailing in the Greek Islands at the moment, finding the right things to do the job with is not always easy here,im installing a new hatch-I have no denatured alcohol, but will wash with water and give a quick wipe with acetatone- by the way I love your boats, I was at a warran round up a few years back-N. Palm Beach and saw your work and met you-I was in my dink-thanks to all!
Old 07-03-2011, 07:19 AM
Rep: 50 Posts: 85
Thanks Ram, I remember. Denatured alcohol is stove fuel alcohol. Acetone will work.
Boatsmith Inc
(561) 744-0855
www.boatsmithfl.com
Old 07-04-2011, 02:11 AM
TeddyDiver's Avatar
Gollywobbler
Raki.. you can drink the left overs..
Epoxy gelcoat idkfa Materials 5 12-15-2010 09:42 PM
gelcoat over epoxy glassman Fiberglass and Composite Boat Building 8 12-13-2005 12:26 PM
NGA Gelcoat over epoxy lamination ducaes Fiberglass and Composite Boat Building 2 03-11-2005 07:12 PM
Fiberglass with west epoxy over gelcoat? bhd Fiberglass and Composite Boat Building 2 03-04-2005 06:13 PM
Gelcoat over Epoxy wet-foot Boat Design 9 08-16-2004 06:58 PM
