Old 07-21-2007, 11:21 PM
naturewaterboy naturewaterboy is offline
Steel Drum Tuner
Rep: 10 Posts: 210
where in Florida to buy balsa core to repair sole
Anyone know who has end grain balsa to re core a sole? I'm in far south Florida - hope there's someone close by that stocks the stuff.
Wherever you go, there you are...
Old 07-22-2007, 04:30 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 563
Quite a few in the Lauderdale area. Seafarer, Joe's auto (actually a large fiberglass supplier), Many more, check the yellow pages. or go on line.
Old 07-23-2007, 09:24 PM
Steel Drum Tuner
Rep: 10 Posts: 210
Thanks. To do a flat floor, should I use the kind that is cut into blocks with a cloth backing? I forgot what they call that.
Old 07-23-2007, 10:57 PM
JRL JRL is offline
Im with stupid
Rep: 25 Posts: 83
I buy a lot of my stuff from Merritt Marine. Its main warehouse is down in Ft. Lauderdale.
Old 07-25-2007, 05:52 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
You seem to be describing Kligacell (not the right spelling) that is used for curved surfaces. There are a few different sandwich materials that will work better. I am a touchy feely guy and I go to Merritt or Seafarer and see what I'm getting. You should also. They will explain the qualities of the different materials. It's worth a drive up north.
balsa core Mihajlo Fiberglass and Composite Boat Building 1 10-22-2006 10:18 AM
Repair a balsa core yacht Anders Radmark Fiberglass and Composite Boat Building 5 07-31-2006 08:42 AM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 11:12 PM
Where can I buy some Balsa Core for my J 29 Cliff Ruckstuhl Materials 1 07-18-2005 07:45 AM
Wet Balsa Core Repair Cliff Ruckstuhl Sailboats 3 07-10-2005 12:53 AM
