Old 06-27-2010, 04:46 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Where to begin
Hi, I am looking at building a storm hood to cover my sliding companionway hatch on my Tanzer 26.
I have used epoxy and glass to repair tabbing, parts and rebuild a mast step but I have never gone about fabricating a piece from scratch before.
It is basically a rectangle with around 3-4" deep lip and I was thinking I would core it wit a thin core-cell foam.
So I have been reading here and there about plugs,molds, and materials to make them and I am at a crossroad and thought I would ask for some help and opinions on what others would use to make such a part.
Any thoughts?
Old 06-27-2010, 06:28 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Is it critical that this thing be as light as possible?
If you're not trying to get it to be ridiculously light, I think you'd be far ahead in time, cost and ease of construction if you just build it out of wood and epoxy. Building a mould takes at least as long as building the part you'll get from it.
Old 06-27-2010, 07:01 PM
dskira dskira is offline
Rep: 1305 Posts: 1,372
Matt intersting design.
It is in development stage?
Daniel
Old 06-27-2010, 07:05 PM
marshmat's Avatar
Daniel- yes, that thing ( Trailer cruiser revisited... as a trimaran ) is in development and I'll be starting to build some of her components later this summer.
CSX- sorry for the digression.
Old 06-27-2010, 10:05 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
no problem.
nice vessel too.
I'm not real concerned about weight, but I don't mind taking the time to learn the mold etc. and the less weight the better
If I made a plug what type of wood would I use?
maybe a female mold out of Styrofoam would be easier?
Old 06-28-2010, 05:30 PM
apex1
Any wood for a mould. Styrofoam is much trickier to handle than wood.
The easiest way I am aware of, is ply over temporary frames (I assume you have a "profile" in the hatch?), probably two sheets of thinner ply to make bending easy. It is hard to beat a sheet of ply in terms of weight to strength relation.
Properly sealed it may outlast the rest of the boat.
Regards
Richard
Old 06-28-2010, 06:49 PM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 272 Posts: 553
And if you build those frames with reverse curve, and substitute Abitibi or other "whiteboard" for the plywood, presto-zoomo--instant mold. You can build the lip around the edges right in the mold.
You'll likely want to radius the sharp corner at the lip. I used to use clay (and a #10 screw with flat washer attached, as a "radius scraper") to build the radius. I'd apply mold release wax to the clay with my fingertip, and I'd make sure there was a sufficient layer of gelcoat over the clay in order to sand and polish the less-than-ideal finish to perfection.
Old 06-29-2010, 05:19 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Is there a certain type of clay that needs to be used?
The white board sounds like a good idea.
Easy to bend
Old 06-29-2010, 07:58 PM
tinhorn's Avatar
Rep: 272 Posts: 553
I used a clay that came from a fiberglass supplier. I'm not sure if a kid's clay is suitable, but I suspect that even peanut butter would work if it was thick enough not to flow. (I've built tons of molds from whiteboard. To avoid nail holes, use contact cement.)
Where to begin? mosquitolaGOON Boatbuilding 3 04-14-2008 07:56 AM
where do i begin? jeremy5780 Boat Design 2 01-10-2008 11:30 PM
Do I need to begin again ?? ford-m Fiberglass and Composite Boat Building 3 05-20-2007 06:58 AM
Where do I begin? B22any Boat Design 1 09-08-2006 02:49 AM
Where to begin? eitanwaks Boat Design 7 07-15-2006 05:48 PM
