#31
| Is this what we're looking for? http://www.usplastic.com/catalog/pro...uct%5Fid=20800 Or do we just want to use polyethylene sheeting like home builders use? Like this one. http://www.usplastic.com/catalog/pro...duct%5Fid=1413 MIA |
#32
| I got mine and it works perfectly, by allowing the "amine bloom" in the curing process to move to the outside of the taffeta to be peeled off after the curing process allows bogging/sanding/painting to proceed easily...
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
#33
Here is a source for the stuff, and there are others. Google 'polyester sheet', a brand name is 'Mylar'. http://www.eplastics.com/Plastic/Myl...FQUhnAodfDtrJQ |
#34
Cost wise though, it was a lot dearer than those links you supplied. The other great use for it is as a sacrfiicial mould. Lay some objects on a table, lay the Mylar on top, and apply FG. The Mylar will stay in the shape you laid it (sometimes with the help of a bit of goo on the underside) and that FG will cure with a perfectly smooth curved and fitting underside. |
| 16-18' "Sit-in" Planing Monohull ("Trapwing") | Doug Lord | Sailboats | 124 | 04-23-2009 06:14 PM |
| Hermann Görings Motor Yacht "CARIN II" rotting away in the Red Sea | Metronicity | Open Discussion: All Things Boats & Boating | 55 | 05-14-2008 04:17 PM |
| "Great Stuff" for flotation foam? | crasea18 | Materials | 2 | 04-23-2007 01:52 PM |
| 45' mast 6" by 9" with all the stuff on it | 7393452 | Marketplace | 0 | 12-16-2006 04:48 PM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 03:03 PM |
