Old 08-09-2009, 10:53 AM
naturewaterboy naturewaterboy is offline
Steel Drum Tuner
Rep: 10 Posts: 210
what are these spots in my gelcoat?
I have some small (most are about 1mm) diameter round "holes" in my gelcoat, all on the sides of the boat, at or below the waterline. I stripped the bottom paint off the hull, sanded a little with 80 grit and found these all around the boat. They seem to be more on one side of the boat than the other. They are not very deep - they don't seem to go thru to the glass - maybe 1/2 mm deep or less. Any ideas what they are, and are they a problem?
what are these spots in my gelcoat?-camera-roll-k2-iphone-062.jpg  what are these spots in my gelcoat?-camera-roll-k2-iphone-069.jpg
Wherever you go, there you are...
Old 08-09-2009, 11:41 AM
ondarvr ondarvr is offline
Rep: 226 Posts: 636
How did you strip the bottom paint off?
Old 08-09-2009, 01:55 PM
mark775
Imperfections/ foreign matter in the gelcoat that you sanded "a little" through. One of the spots (green) looks to be the color of PVA (polyvinyl alcohol) used as a parting agent. The blue, I don't know. I believe that the builders were a little sloppy but also that you were too aggressive sanding.
Old 08-09-2009, 09:55 PM
Steel Drum Tuner
Rep: 10 Posts: 210
On the sides, I just sanded with a 6" Festool DA sander in the rotary mode. It doesn't sand in a pure, rotary pattern like a grinder does, it wiggles around a little. I'll look closer at the color of the spots. The blue is probably bottom paint.
Old 08-10-2009, 02:18 AM
Rep: 226 Posts: 636
They most likely scraped barnacles off the hull and then bottom painted it, they can take chunks of gel coat off.
Old 08-10-2009, 04:25 AM
Boatpride Boatpride is offline
Boatpride
Rep: 10 Posts: 37
Once barnacles take hold, they bore through the gelcoat into the fiberglass - if unchecked. They get more and more secured. So when its time to remove them, then as Ondarvr suggests the gelcoat comes away in chunks.
If you would like to read a post on fixing gelcoat follow this link
Gelcoat Repair
Hope that helps!
By Chris
author boatpride.com
Virtual sailing resources and products, an interactive, multi media experience! Leave a video / audio /written comment!
Old 08-10-2009, 07:08 PM
Steel Drum Tuner
Rep: 10 Posts: 210
I am repairing the bottom with epoxy resin, so I'll fill these with some epoxy, as it is all going to get painted with Interlux 2000E barrier coat and then a bottom paint - probably Petitt Vivid Eco. Thanks for the answers - the holes probably are from barnacles, as the bottom paint was pretty well gone when I bought the boat, and it had a lot of hard growth on it.
Old 08-16-2009, 11:04 AM
mikereed100 mikereed100 is offline
Rep: 30 Posts: 82
Possibly styrene that was incompletely mixed with the gelcoat?
Mike
Old 08-24-2009, 12:56 PM
mastcolin mastcolin is offline
Rep: 96 Posts: 89
Bubbles in the spray-on gelcoat?
They were closed till you sanded?
Fill them with epoxy, paint.
Have you checked the hull for moisture content? Not that it can necessarily mean anything but if it is very high and you put on the epoxy system you may encourage osmosis later in life.
ps so the holes maybe the gelcoat osmostically breaking down for the reason given previous - pva, stryrene, bad mix, too much catalyst
Regards
Colin
Old 09-12-2009, 10:40 PM
Steel Drum Tuner
Rep: 10 Posts: 210
I haven't checked the hull for moisture, but it has been sitting on land for 5 years, and I've had a tarp rigged up for shade over the boat for the last two. It also keeps most rain off the boat.
Old 09-13-2009, 03:14 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
OK, so we have:
-barnacles
-unmixed styrene
-bubbles in gelcoat (less likely)
I would like to add:
-unmixed drops of peroxide in gelcoat. (malfunctioning spray equipment).
That can also be the cause. However, both unmixed styrene, mek or peroxide, or bubbles, are likely to cause problems on the surface directly after demoulding, so at least should have been taken care of by the manufacturer.
Luckily solving this problem is not difficult nor expensive.
Old 09-13-2009, 01:30 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
contamination is my guess and it looks suspiciously like some moisture was present in the compressor/pipes when spraying the gelcoat.
Funny, we sprayed some epoxy paint this week on the deck of a 6 meter daysailor with the same symptoms - left small patches of pin holes holes at places on the primer that will not cover.
Found out the guys did not drain the compressor for a couple of days and after doing so, the problem disappeared.
Wynand
A scatterling of Africa
Old 09-13-2009, 01:49 PM
Herman's Avatar
Resininfusion.info
Forgot about moisture indeed.
On all your machines, have a moisture trap installed, and get the one that drains automatically.
When spraying with a spraygun, have a moisture trap (and pressure regulator) as close to the gun as practical.
Old 09-14-2009, 12:40 AM
Rep: 226 Posts: 636
They don't look like water or catalyst drops, Water leaves round pits, catalyst will leave soft spots that will deform the surface. These look like chunks that were removed from something sticking to the surface.
Old 09-16-2009, 09:42 PM
Steel Drum Tuner
Rep: 10 Posts: 210
It probably is attack from marine organisms - probably barnacles - as the bottom paint pretty well gone in around the waterline when I bought it. Thanks to everyone for your ideas.
Hard Spots in Hull Side Capt. Chris Fiberglass and Composite Boat Building 2 09-04-2007 09:02 PM
Hard spots on keel? tuantom Fiberglass and Composite Boat Building 1 07-27-2007 11:42 PM
soft spots in fiberglass floor LEASEGUY Fiberglass and Composite Boat Building 13 08-26-2006 10:08 PM
white spots in fiberglassed bottom Nordson1960 Wooden Boat Building and Restoration 1 03-24-2005 06:52 PM
Spongy spots in the floor eusscmp Fiberglass and Composite Boat Building 6 11-17-2004 03:26 AM
