Old 10-14-2009, 04:44 AM
Bango String Bango String is offline
Rep: 10 Posts: 2
What sort of weight loss can I expect from poly resin in an open mould
Does anyone have any idea about how much weight is lost by Styrene evaporation during an open mould lay up?
I've picked up data some about loosing 60g/sqm. Any ideas or experience?
Banjo
Old 10-14-2009, 05:47 AM
Rep: 1397 Posts: 7,216
It depends on the styrene content of the resin. Figure the percentage of styrene in weight and deduct that from the total weight of resin used in the laminate.
Old 10-14-2009, 05:58 AM
apex1
There is no such per m² figure! It depends on the resin you use (how much solid content) and of course on the weight of the layup. A 100gsm roving needs about 100gram of resin where a 320 gsm fabric some 320 gram of (solid) resin sucks.
So, when you have a resin with 60% solid you should calculate that 40% of the dilusive/thinner will evaporate (and should).
Regards
Richard
edited: I should type faster...........gonzo got it already
Old 10-14-2009, 08:22 AM
Rep: 10 Posts: 2
Thanks, that answers a lot and would explain my 30% difference between what went in and what came out.
The next question is sometimes the difference is 28% other times it 31%. Assuming that the weight of product is constant. Will anything change the amount of VOC that escapes? Temp, Humidity, air flow over the part? time between hits? or is it a case that 100% of the VOC will always eascape?
Old 10-14-2009, 08:55 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1943 Posts: 4,195
There is a weight reduction when the resin dries out, it is however neglectable. You will have more of a weight problem with your method. Hand layup means you use the same amount of resin as the glass weight, where it is ideal to have a 50% resin to glass weight ratio. Remember the resin does not contribute to strength much, like nothing.
Besides the weight, it is also costing you double the resin.
Regards
Fanie
Water ! Just gimme water !
Old 10-14-2009, 10:20 AM
The styrene content is not always exact. Are you mixing the resin?
Old 10-14-2009, 02:37 PM
Fanie's Avatar
Fanie
If you want to save on weight then one method would be vacuum injection. Two reason's I don't like is you use a lot of consumables and there is a chance of the process failing. Whatever you were going to save in terms of the resin the consumables gulp up. The final product however comes out about 25% lighter, since the glass is 1kg vs about 500g resin.
I am currently preparing another method of wetting the glass. I made a glass feeder that rolls the excess resin out, and the idea is to so obtain wetted glass with no excess resin, target ratio glas vs resin is also 2:1.
No consumables other than peel ply needs to be used, and the wetout is continuous, only stopping to put a full glass reel in and filling the resin up. I'm negotiating with the glass weavers to make the glass reels narrower from 1m300 so they handle and apply easier to a width of 650mm.
Regards
Fanie
Old 10-14-2009, 02:59 PM
apex1
Additionally the dilutives, solvents need much longer to come out in thicker layers and low temperatures. In some poor layup you will have styrene vapor after one year! Even some "big brands" have proven that.
Old 10-15-2009, 08:35 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Please do remember that most of the styrene will co-cure with the polyester. The tests I have done typically show a 7% weight loss (approx). This is using DCPD resin (low styrene content of some 30-40%, and fast final cure)
Any residual uncured styrene will yellow over time, that is why polyester slowly turns brown. Also, in gelcoats, you can have the same problem, when for some reason the final cure is not achieved.
About cutting rolls of fiberglass: This should not be a problem, using the right equipment. I can direct you to a piece of equipment that works.
Old 10-15-2009, 10:45 AM
I mean if you are mixing the resin well before taking it out of the container. The solids settle and give you different percentages of styrene
using epoxy and poly resin to do repair 61sg Fiberglass and Composite Boat Building 20 08-20-2009 05:28 PM
9 month old poly resin pescaloco Fiberglass and Composite Boat Building 16 02-11-2008 10:21 AM
Laminate resin weight and volume fraction jacobe Materials 6 09-30-2006 04:06 AM
Laminate resin weight and volume fraction jacobe Fiberglass and Composite Boat Building 4 09-29-2006 12:56 PM
What type of resin to use? epoxy or poly. for this hole in Bow? J-Bird Fiberglass and Composite Boat Building 4 12-25-2005 12:21 PM
