Old 07-14-2009, 07:32 PM
merrile merrile is offline
Rep: 10 Posts: 8
What should I remove first, Transom or Stringers?
The sole is out should I take out the transom first and replace it then move onto the stringers?
Old 07-14-2009, 07:40 PM
Rep: 501 Posts: 1,767
Neither, but removing the transom will cause you to sink first...
Old 07-14-2009, 09:29 PM
Rep: 3125 Posts: 9,399
It really doesn't matter, though you may encounter stringer to transom relationships issues, when re-doing the transom core, so I'd recommend the transom first.
Old 07-14-2009, 11:00 PM
Rep: 10 Posts: 8
Kinda what I though but common sense isn't alway a common virtue!!!!
Oh what I wanted to do the transom first anyways!
plywood transom/stringers? stilloutoffocus Materials 8 06-17-2009 11:21 AM
Stringers and Transom - cloth weight MercMark Fiberglass and Composite Boat Building 5 06-13-2005 09:24 AM
Stringers and transom - cloth weight MercMark Materials 0 06-02-2005 01:10 PM
Attaching stringers to transom? mikkyle Fiberglass and Composite Boat Building 3 12-13-2004 02:21 AM
Is ther an easy way to remove stringers? Saltyredfisher Boatbuilding 8 05-25-2004 08:13 PM
