Old 10-01-2009, 11:11 AM
pescaloco pescaloco is offline
Rep: 19 Posts: 231
Wet sanding with electric sander
Ok before you fry me for water and electricity bit, no pun intended.
I need a way to wetsand large areas of gelcoat where it would not be be possible to have a high volume compressed air source.
I used a orbital paml sander and water spray bottle, the $70.00 sander made it through 1/2 of a 43 footer. I don't mind spending some more money for a quality tool intended for the purpose, but it would have to last ofcourse.
Do you guys know of an electric sander/polisher that would be sutible for 600-800-1200 grit wet sanding on gelcoat.
Thanks much
Old 10-01-2009, 12:26 PM
Dan H's Avatar
Dan H Dan H is offline
Rep: 10 Posts: 23
I was doing the same thing. The bearing on the bottom died because the sander I was using was a dust collector type. When the bearing went, it melted the plate. The bearing got wet. I used a dewalt 1/4 sheet palm sander.
I bought two new plates and two new bearings. I sealed the vacuum channels on one plate to use for wet sanding and the other for sanding when I want the vacuum.
I use a spray bottle, rubber boots, and a GFI extension cord.
I haven't tried it since I repaired it, but I don't know why it won't work. It worked before it broke.
Never mind the Avatar, I'm not Mr. Incredible, I just really enjoyed the movie.
Old 10-01-2009, 01:32 PM
steele m.a. steele m.a. is offline
Designer/Engineer
Rep: 10 Posts: 44
wetsand
Try : NorthernTool.com
M.A. Steele
Venture Hulls (Canada)
Old 10-02-2009, 10:55 AM
Rep: 19 Posts: 231
thanks for the replies, will check Northern Tool
You know mine is the dust collector type also, and water definetly caused the bearing to fail.
Old 11-28-2009, 06:29 PM
david@boatsmith david@boatsmith is online now
Rep: 26 Posts: 81
We redo solid surface counter tops in boats with electric DA sanders this way. We use Porter Cables and keep the speed down. Lots of protection to prevent unwanted damage and limit the amount of slurry. Velcro paper works better than PSA but we have done it both ways. David www.boatsithfl.com
Old 11-28-2009, 07:36 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
Try an air powered sander, but you need a good-sized compressor. Use a GFI protected circuit if you use an electric sander so you won't be electricuted by accident..
Old 11-28-2009, 09:19 PM
Dan H's Avatar
Rep: 10 Posts: 23
I have my Dewalt electric orbital sander working with the platen that I sealed off. It's working great.
I have 600 grit on it, 1000 grit on my Jitterbug air sander and hand sand with 2000 grit. Getting great results, but I'm having a devil of a time finding the right wool polishing pad.
Old 11-29-2009, 04:13 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
get a Mirka Ceros electric sander. These run on 22 volts, so much safer to use then 110 or 220 volts. a voltage convertor is included.
Old 11-30-2009, 07:43 AM
Rep: 472 Posts: 1,391
Guys, I do this all the time. The trick is don't use to much water. You wet the surface not the sander. Tie extension cord over your shoulder so it doesn't fall in puddle. Wear rubber shoes, have good drainage, stand on thick piece of wood. etc... I also use gfi. Never had problem being doing it for many many years. Dont get sander wet, oh I used sanding paper without the little holes.
Best delta shaped sander? GWB Wooden Boat Building and Restoration 0 04-08-2008 11:58 PM
sanding jbowers417 Wooden Boat Building and Restoration 21 09-20-2007 11:03 AM
wet and dry sanding bojangles Fiberglass and Composite Boat Building 9 04-07-2006 02:15 PM
Orbital Sander Advice nero Fiberglass and Composite Boat Building 5 07-17-2005 11:31 PM
Best sander yet!! Fastredblur Materials 6 08-13-2004 11:03 AM
