| Wet Balsa - again Problem with high moisture readings above waterline and so called blisters due to moisture in GRP - I suppose. I want as easy as possible save this boat for another 30 years. I can mould outer skin in an easy way. I heard from a boat man that it is possible to drill a lot of holes in the balsa cored hull and let the balsa dry out before, when dry enough, filling the holes with epoxy and make a new outer skin. And inner skin as well - I guess. The epoxi in the holes between outer and inner skin give enough strength to the hull I suppose. Have anyone experiece from a process like this? Can this be possible to do? Anders |
| yessiree bin der done that, works ok, but! cut out the offending area and fill it with a sandwich material. then put the deck back down. Works better
__________________ Can anyone spare any gas today for a hamburger on Friday ??? |
| Balsa filler | rturbett | Fiberglass and Composite Boat Building | 1 | 02-02-2006 05:45 PM |
| toughened balsa | mark roberts | Materials | 6 | 11-20-2005 02:54 PM |
| Wet Balsa Core | Cliff Ruckstuhl | Materials | 2 | 07-11-2005 08:14 AM |
| Wet Balsa Core Repair | Cliff Ruckstuhl | Sailboats | 3 | 07-10-2005 12:53 AM |
| I am all wet!! | Candyman | Open Discussion: All Things Boats & Boating | 8 | 07-21-2004 01:18 PM |
