Old 05-16-2006, 02:55 AM
Roly Roly is offline
Rep: 222 Posts: 490
West sys. glue mix
Is the blush as prevalent using west system and microlite thickener?
I have some glue lines that are concave and require extra filler. I dont want to scrub because of raw timber;Will a lite "edge folded" hand sand surfice?
Old 05-21-2006, 11:50 PM
Rep: 95 Posts: 462
thats what i would do
Old 05-22-2006, 09:48 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
You want to wipe it down, then sand, then wipe again. If you sand then wipe, you might just be grinding the blush into the surface.
Joel
Old 05-23-2006, 01:18 AM
Rep: 222 Posts: 490
Yep, I agree,but I don't want to wet the bare timber. Winter is coming on
and the timber will be starting to absorb moisture. I will heater the hull inside
prior to glassing. (In a couple of weeks. )
Just a thought, but what about giving a vigourous wipe around with a epoxy
wet brush to take up the amine blush and redistribute it into the next mix?
Looking for molds on the west coast 22-28 COLE Boat Molds 3 04-18-2007 12:21 PM
oil mix for johnson hydro electric V115? revshot Propulsion 0 02-10-2006 01:29 PM
Kerosene Mix With Diesel PADDLEGUY Open Discussion: All Things Boats & Boating 15 02-06-2006 03:29 AM
Sit - mix a drink - sail fast... Sean Herron Boat Design 5 03-14-2005 10:44 AM
Placed to buy mix and pour foam jtdouglas3 Fiberglass and Composite Boat Building 3 10-01-2004 05:23 PM
