Old 02-11-2008, 06:23 PM
lesburn1's Avatar
lesburn1 lesburn1 is offline
Rep: 59 Posts: 20
wax less Polyester resin and PVA
So here is the issue, I want to make some vacuum bagging tools and I have polyester resin on hand that is wax less. Can, after I layup my last layer of glass to make the mold (tool) and the polyester resin gels up spray on a coat or two of PVA to insure a hard cure of the outer most layer?
Old 02-11-2008, 11:06 PM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 253 Posts: 526
I say yes, you can. As I understand it, it's the reaction to oxygen in the air that keeps the skin tacky. No oxygen, no tackiness. To insure "hard cures", I've placed parts in sunlight. Because God prefers fiberglass to aluminum, He's filled sunlight with ultaviolet rays that will cure even low-catalyst layups.
Not sure you'll like the finish, though. I've never seen a raw polyester or vinyl ester part that wasn't full of pinholes. This is why God created gelcoat.
Old 02-12-2008, 08:47 PM
Doug Lord
Why would you invest in tooling made of polyester? And you know that naked polyester is going to want to absorb some of the moisture when you wash off the PVA...
Old 02-12-2008, 08:53 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
lesburn1,
When making tooling, we first make a plug, the mould is then laid over the plug, the resin sets and the plug is removed, and the mould tool is created, you seem to be arse up in what you are doing mate.
Old 02-13-2008, 08:50 AM
lesburn1's Avatar
Rep: 59 Posts: 20
Lets see if I've got this right.
First I need a plug to make my tool.
Yes, got that.
Put on the gel coat and glass to make the tool.
Yes, done that part before, know about that.
So, to get back the the original question,
if the outside surface (not the molding surface) is still
tacky, can I use PVA to promote a full cure?
Thank you "tinhorn" for an answer. (although I'm not sure that god concerns herself with my molds)
Old 02-13-2008, 11:45 AM
ondarvr ondarvr is offline
Rep: 226 Posts: 633
Yes, it will reduce or eliminate the tack of the resin, but it needs to be used very soon after the resin is applied and still uncured, it will do almost nothing at a later date.
Old 02-14-2008, 04:17 AM
pacific808 pacific808 is offline
Rep: 10 Posts: 2
yes you can!
Polyester resin and plywood Whale1 Fiberglass and Composite Boat Building 4 01-22-2008 08:30 PM
epoxy vs polyester resin mkpardy Boatbuilding 11 01-23-2007 11:23 AM
Polyester resin roko Fiberglass and Composite Boat Building 10 11-28-2005 08:39 AM
Oops--Removing Polyester resin Wax Fishtale Fiberglass and Composite Boat Building 4 01-10-2005 10:26 PM
Removing polyester Dresin wax Fishtale Fiberglass and Composite Boat Building 0 01-08-2005 08:51 PM
