Old 01-22-2012, 09:48 PM
kapnD kapnD is offline
Rep: 19 Posts: 143
vinylester sanding coat
Does anyone know if surfacing agent will work with vinylester resin?
I want to put a finish on my VE layup, and would like to make the final coat tack free for sanding purposes.
Thanks, Don
Old 01-22-2012, 11:10 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
Works fine.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 01-23-2012, 07:11 AM
Rep: 1493 Posts: 7,447
If you mean wax, yes.
Old 01-27-2012, 12:49 AM
Rep: 19 Posts: 143
Thanks, guys, I thought it was probably ok, but couldn't find it in writing. Will put it to the test in the morning!
Old 01-27-2012, 05:14 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
paraffine solution in styrene, which is what you guys call wax, indeed works fine. But there are curing agents that make the VE cure non-tacky.
Old 01-27-2012, 08:18 AM
david@boatsmith david@boatsmith is offline
Rep: 50 Posts: 85
I too have wonered about this. We are building cat hulls over a male mold and I thought about using wax to make it sand better and sooner but am worried about wax contamination for additional fairing. Is this not a concern? What might the other curing agents be?
[IMG]
100_2999 by boatsmith, on Flickr[/IMG]
Boatsmith Inc
We Build Your Dreams
(561) 744-0855
www.boatsmithfl.com
Old 01-27-2012, 02:27 PM
Cawley Cawley is offline
Rep: 26 Posts: 11
VE cures pretty hard and tackless anyways compared to ISO poly. I use it all the time and find it ok to sand. I would not put the wax in it. JMO
Yet another epoxy vs vinylester ... fcfc Fiberglass and Composite Boat Building 33 11-14-2011 01:53 AM
Milky Vinylester mikereed100 Materials 15 02-11-2009 01:07 PM
vinylester vs epoxy adamfocht Fiberglass and Composite Boat Building 7 01-03-2007 06:45 PM
Vinylester over epoxy... NO !!! Capt. Chris Materials 3 09-25-2005 12:12 AM
Vinylester / Epoxy miguel_noe@yahoo.com Materials 1 08-11-2003 01:18 PM
