Old 02-13-2012, 08:17 AM
fcfc fcfc is offline
Rep: 359 Posts: 709
vinylester infusion basics ?
Infusing gelcoated hull.
From what I understood, you can wet laminate one or two layer of CSM on the gelcoat. And only after hardening, you can put the dry fiber, and process for the infusion.
Is there a way to get rid of that intermediate wet lamination , keeping good surface aspect , and good bonding for the gelcoat ?
The structural lamination may be 1.2kg biaxial glass,2mm soric lrc, 1.2kg biaxial glass up to 2.4kg/3mm/2.4kg. And the soric lrc to be the infusion media.
Thanks.
Old 02-13-2012, 09:15 AM
latman latman is offline
Rep: 14 Posts: 48
LRC prints badly (surface aspect?) on lightweight laminates with my 200gsm plain fibre you may be "insulated" using 1.2kg fibre , TF is the best "surface aspect" (but slow to infuse) I think you can leave out the "tie layers" only if you want to save weight but you would need your resin to vertically penetrate a thick layer before it hits the Soric and flows horizontally.Remember the process of infusion increases your % fibre and therefore fibre print is likely worse.
Old 02-13-2012, 08:22 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Like latman said, print is an issue with infusion. One of the skin coats main functions is to reduce the amount of print.
Old 02-14-2012, 04:13 AM
Rep: 359 Posts: 709
So, whatever the resin you use for infusion, you need a skincoat ?
For polyester, you need a VE skincoat for osmosis and printthru.
For epoxy, ( Infusion Q&A ), you need it for gelcoat compatibility.
And for VE resin, you still need it for printthru.
But do you still need a peelply for skincoat if VE infusion ?
How long do you have to wait before placing dry fiber, before apply vacuum, before resin flow ? Or is it the opposite, do you have a maximum time not to go over for the infusion resin if you want a good bond between skincoat and infusion ?
Thanks.
Old 02-14-2012, 05:36 AM
Rep: 14 Posts: 48
I would personally use a regular VE with CSM for the tie or skin coat one day, then next day load all your materials and infuse with VE ASAP (but do a test using all ingredients before !!!) I would not put peelply on the skincoat but i would inspect it after curing with a piece of sandpaper and knock off any protruding fibres.
Old 02-14-2012, 09:46 AM
Rep: 359 Posts: 709
Found that old thread, but with no answer ...
soric core material printing thru???
Old 02-17-2012, 02:47 AM
susho susho is offline
Composite builder
Rep: 62 Posts: 66
Skin coat with peel ply gives the best adhesion. VE gives a lot of print, so 2 layers of csm is a usefull adittion. Vinylester infused boats often get sanded and spray painted here if a top surface quality is needed.
Old 02-17-2012, 04:21 AM
Rep: 359 Posts: 709
But where is the point to use a mold, if later you need fairing ? Also paint do not last as long as gelcoat.
And the problem of peel ply in the whole hull, is that you need man hours to put it, and man hours to remove it.
Old 02-20-2012, 02:07 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
The print-free boats that I see here, usually have a 225 gr CSM and a 450 gr CSM as skin coat. It also makes it possible to walk in the mould.
Old 02-21-2012, 08:27 AM
Rep: 359 Posts: 709
675 gr CSM hand wetted at 0.3 makes 2.2 kg per m², + gelcoat. Roughly 3 kg/m² just for surface finish, no structural.
Am I correct ???
Old 02-21-2012, 09:42 AM
Herman's Avatar
Resininfusion.info
Yes, that is correct.
Epoxy V's Vinylester Infusion Bilf Fiberglass and Composite Boat Building 13 01-20-2012 04:37 PM
Polyester basics Michail Materials 6 09-15-2011 03:05 AM
WTB: used books, articles, videos on resin infusion / vacuum infusion Ern.Bieman Marketplace 0 04-28-2011 09:41 AM
lofting basics help HO229 Boat Design 59 03-15-2011 10:17 PM
Back to Basics amdega Boat Design 2 02-11-2009 05:26 PM
