Old 03-02-2009, 06:00 PM
apex1
Originally Posted by basslover911 View Post
^^ I am first going to make a simply road bike frame to see what shapes I can do and how strong I can do it. After I will make a kayak.
Plus price per price (like I mentioned earlier) you dont have to buy the epoxy and stuff so the price ends up being only slightly higher for prepreg but you dont have to worry about many other things (just heating it right).
Would you please do me a big favour? Tell us the source of your cheap prepreg! Some of us here build several boats a year and could save a hell of a lot of money, if only we could save labour, making a very dry layup without wetting out the fibre by hand or infusion!
As you call a bike frame in carbon "simple" you must be really experienced.
Regards
Richard
Old 03-03-2009, 05:00 AM
AndrewK AndrewK is offline
Rep: 338 Posts: 377
Basslover, the other thing to keep in mind when comparing cost of prepreg and wet layup is wastage. With prepreg the offcuts that you can not use you end up throwing away resin as well. In wet layup you only waste the reinforcement.
If you only use vacuum for consolidation then the strength and weight of the prepreg and wet layup will be the same. Providing you cure both at the same temperature and you use comparable quality epoxy for the wet layup.
Old 03-03-2009, 11:13 AM
basslover911 basslover911 is offline
Rep: 10 Posts: 7
^^ Well a bike frame is just simply "tubes" so you just wrap the fibers around and around and around... haha its just as if you were making tubes no big deal.
As for wastage, I think you waste more resin during wet layups (if you "vacuum" it out) than you could ever waste by throwing little pieces away. I think with prepreg the big thing is planning out how you want to cut it as to maximize those strips. And i am not worried about strength THAT much, but about "messing up"; theres so much to go wrong with infusion or simple hand layup (bubbles, delamination down the road, etc) that even with the little bit of added cost of prepreg its worth all the troubles.
Old 03-03-2009, 11:38 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
I think that if you do some research you'll find that most carbon fiber tubes are filament wound, pultruded or roll-wrapping (which is similar to what you're describing). Tubes with lower structural requirements can be fabricated from knitted sleeves and hand laid up. I have made a few of these. I have tried 'roll-wrapping" and it's a real PITA. Most roll-wrapped carbon fiber tubes I've seen are used on kites & tents etc.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 03-03-2009, 01:01 PM
apex1
Forget it..... absolutely hopeless... wrap around and around and .......miracle.. you have a bike................
Vacuum infusion and splitmold? Danielsan Materials 12 04-14-2005 09:16 AM
vacuum bagging or vacuum infusion Eisa Hasan Fiberglass and Composite Boat Building 10 03-29-2005 03:25 PM
vacuum infusion laminating HWL Fiberglass and Composite Boat Building 40 03-28-2005 01:38 PM
Vacuum Infusion Wf benadeline Fiberglass and Composite Boat Building 1 05-07-2004 09:10 AM
vacuum infusion big cat Boatbuilding 7 10-06-2002 01:51 PM
