| Vacuum Infusion Wf what kind of fibre weight fractions can be expected from CSM and WR using vacuum infusion and polyester resin? |
| The key to resin infusion processes are the process vacuum. I use to work for a company doing commerical research, so I have quite a bit of practical experience. Ideally it would be nice to have a perfect vacuum. However if your a good bagger, on a large boats you may pull 50mb (absolute). I wouldn't infuse something big without a good vacuum. Don't forget, infusing on warm high pressure days are good for high Vf. I would estimate somewhere in the region of 45-60% Vf. Wovens and randon mats are poor for high Vf due to there structure. Make a trial laminate, as you can estimate Vf. By measuring weights of fabric to resin etc. Or you the equation Vf = number of layers * Areal weight/Density of fabric * thickness. Or do a burn off test. I hope this helps Shaun |
| Solomon Technologies - "Electric Wheel" electric motor propulsion systems | lockhughes | Hybrid | 227 | 07-19-2008 01:00 PM |
| Option One - how big | Willallison | Option One | 43 | 12-20-2005 06:44 AM |
| Vacuum Infusion Process | roko | Fiberglass and Composite Boat Building | 5 | 06-01-2005 01:06 PM |
| Vacuum infusion questions | Seriola Dumeril | Fiberglass and Composite Boat Building | 3 | 03-30-2005 01:26 PM |
| vacuum bagging or vacuum infusion | Eisa Hasan | Fiberglass and Composite Boat Building | 10 | 03-29-2005 04:25 PM |
