| I've ordered the one from Fibermax. There were a couple of better options in the States, but P&P was too much, and they didn't take any responsability as soon as the parcel left the US. I've ordered the whole kit, plus a few meters of different fabrics, epoxy and a couple of tools. It's gonna be early Christmas for me!
__________________ back to composites.... --------------- Quote:
| Sizing a pump depends a lot on the size of the project. Your small vac pump will work on large projects too if you suck down the layup with a shop vac first. That gets you close and let the smaller pump handle the higher vac levels. I've done it that way and plan to infuse our boat project with my 5 CFM pump you saw in the photo posted previously. I also have a Gast vacuum generator as backup and will likely have a third pump (refrigerator pump) and a generator on hand when we start infusing a boat hull with thousands of dollars of materials on the line. A vacuum reservoir helps with larger layups as well. You can draw them down before hand. You can see them here in the background. One is black plastic pipe and the other is white. Very simple and cheap to make from hardware store parts. Probably about 1 cu ft total. The white one has a screw out fitting and is used as a resin trap as well. ![]()
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
How did you make the vacuum reservoir thingy? did you read anything about it first, if so, where? Thanks a lot!
You're welcome. Good luck.
| actually I've been looking at vacuum videos, but not infusion now I'm looking for those plans thanks again
| What is vacuum bagging? | RTaylor | Boatbuilding | 6 | 04-06-2008 01:14 PM |
| Recommended vacuum pumps for vacuum bagging? | James Mills | Materials | 1 | 12-17-2006 03:11 AM |
| vacuum bagging or vacuum infusion | Eisa Hasan | Fiberglass and Composite Boat Building | 10 | 03-29-2005 03:25 PM |
| Vacuum bagging with fabric | brevell | Materials | 1 | 09-15-2004 01:16 PM |
| Vacuum Bagging Question | turnershells | Boatbuilding | 0 | 01-20-2003 12:33 PM |
