| Vacuum Bagging honeycomb core Does honeycomb core material lend itself to vacuum bagging? I am considering trying this when I replace a cabin bulkhead on an old Bertram 25. The finished surface will be painted, so I thought the peelply surface from the vacuum bag would give a nice surface to start with. I have access to partial sheets of Corecell at a considerable discount (Noah's in Toronto) and am also wondering if two pcs butted against each other would be sufficient or would this create a weak panel? Thanks, Ian. |
| Be aware that there is more than one type of honeycomb.I have encountered Nomex and Aluminium in vacuum bagging situations and both do a satisfactory job.You need to be sure that the material you have access to is of the correct density to provide the strength for the job and that it has the flexibility to conform to any necessary shape. |
| Corecell is not a honeycomb, it is a closed-cell foam. It is probably suitable for your bulkhead replacement. I have never seen a satisfactory honeycomb core job done without vacuum bagging, on anything but a horizontal flat plate. Curved or vertical parts with honeycombs simply have to be done under vacuum bag in order to work properly, unless you want the finished product to be 75% resin and way overweight. Nomex and aluminum honeycombs both have a tendency to suck the liquid resin out of the skins; a good layup is not nearly as easy as with solid fibreglass. Honeycombs are complex materials and specifying an appropriate one for a particular job requires a good understanding of the stress distributions within the part. A peel-ply surface has a slight texture, generally comparable to 150-220 grit sandpaper in terms of how much it deviates from perfectly smooth. It is paintable, but to get a mirror-smooth finish will require that you fair it with a microballoon filling compound.
| That's for the replies. I guess I was vague in my question. I understand that corecell and honeycomb are two different materials. My corecell question is will you lose much in stiffness by having multiple pcs of core material within the panel or should I spend the $$ for a continous sheet? If I am bagging a wet laminate (not infusion) do I need to prime the corecell with resin and let it kick? My concern with honeycomb was if the voids in the honeycomb would suck up the resin and create a honeycomb cells full of resin. Thanks, Ian. |
| Honeycomb cores are typically used with prepreg materials where the layup is cured in an autoclave or an oven under vacuum. There is minimal resin flow with this type of system and the hollow chambers don't fill up with resin. |
| Crozier Racing canoes has been vaccume bagging hand lay up carbonfiber/honeycomb for decades. These canoes are 18.5 ft long and weigh less than 30lbs. $4850 will get one for yourself but the waiting list is long. Crozier is getting tired of building. Rimer racing canoes also builds them in a slightly faster but less stable version. Those can be had for about $4400. The trick to bagging honeycomb core parts is to use a two step process which requires a two molds. For example if a 3/8" sandwich canoe hull is being built you need a mold for the inner layer and one for the outer. The inner mold (male) is the same shape as the outer mold (female) except that it is 3/8" smaller to make room for the core material. Building the part: The inner layer of cloth is laid on the male mold and wet out. Then the core material is laid onto the wet cloth and vaccume bagged down. After the epoxy cures the part is removed from the mold and trimmed/test fitted to the outer mold. Then cloth and epoxy are applied to the outer mold. The part from the previous operation is then bagged into the newly wetted cloth to crate the carbon-honeycomb-carbon sandwich. It is amazing how flexible the part is before it gets the second skin. This is a good thing though because that flexibility allows the second side of the honecomb to make good contact as it is bagged down into the wet cloth that becomes the outer hull. I actually have done this process in Rimer's shop and have spent several hours with Crozier in his shop too. |
| I have been vacuum bagging with honeycomb cores since 1986. My process has been to lay up the outer skin in the mold, then fit the prepared honeycomb core ( in my case a Plascore polycarbonate honeycomb product) then lay in the inter skin and install the Vacuum bagging consumables. This presupposes that all the components have been cut to plan before hand and that you are using a very slow resin/hardener mixture. While this works with S-Glass, I have found that kevlar rolls up on a pvc pipe after wet out much better. |
Nothing will happen, just the core will stay in place and have contact with the wetted out surface. Thats why it is done. Regards Richard |
Lets try standing in there shoes with a blank mind looking at what they are asking about. I have often askes "HOW MUCH VAC SHOULD BE USED TO DO THE JOB" i have never had anyone answer ! dont they know or are they to affraid that what they say might not be right ?. ![]() |
| so then Tunnels, here you can shine! What did you mean with: "remembering its got all those voids all over it " ??? And donīt argue when your questions get no reply, YOU are the one claiming to know advanced composites! Although...... |
I have never laid claim to advanaces composites ever ! Have been round the playground a while and been and seen a lot a stuff in differant countries. When asked i will go any where to show others how and to learn from them ! There is no black and white in this industry just varying shades of the color gray ! |
And the honeycomb spaces fill with resin when vac. bagged? How do they do that? In my village they donīt. Tunnels you should stay with what you know, not with what you guess! Richard |
| What is vacuum bagging? | RTaylor | Boatbuilding | 6 | 04-06-2008 02:14 PM |
| Vacuum bagging and Vinylester | fede | Fiberglass and Composite Boat Building | 10 | 12-19-2006 04:32 AM |
| Recommended vacuum pumps for vacuum bagging? | James Mills | Materials | 1 | 12-17-2006 04:11 AM |
| vacuum bagging or vacuum infusion | Eisa Hasan | Fiberglass and Composite Boat Building | 10 | 03-29-2005 04:25 PM |
| vacuum bagging info | Psycho D | Fiberglass and Composite Boat Building | 1 | 10-04-2003 08:23 PM |
