| Vacuum bagging bulkheads When bagging Airex sandwich bulkheads (or other flat parts) on the table, how I avoid the entrapped air at the lower skin? Should I bag the skins separately or use breather fabric at the lower skin as well? Maybe perforated foam? Anyone have similar problem? Which setup do you use? ![]() |
| Predrilll your foam. Resin will fill the hole after all the entraped air is removed. I put a small page together awhile back to help another potential builder out. I never finished it but you should get the jist. http://www.geocities.com/bcrepeau.geo/index20PANEL.html Good luck Bob C. |
| hello nassaw. I'm also intrested in this technique but your page is not found...?? How do you prevent the lower skin to glue to the table ? simply by waxing and peelply ? |
| Wax the table to avoid adhesion. You could use peelply, but it is optional (at least on the table-side) |
| Sorry about the page. Its a free site from geocities and they allow a certian amount of bandwidth. When this is reached they shut down the site until more is allocated. Just try back later. The table must be waxed peferably with a good mold release. Don't use a car wax. Car wax is made up of many chemicals, Some that are not compatable with resin and others like teflons that are tough to remove when it comes time to finish, The table can be treated like any mold and panels can be completed to gelcoat on the table side, If panels are to be put together to create a larger panel. Rebates and edge treatment are critical and time saving. I also have a joins sheet on a page. If interested just email me and I will post directly to you saving the bandwidth. Regards Bob c. |
| Solomon Technologies - "Electric Wheel" electric motor propulsion systems | lockhughes | Hybrid | 228 | 10-12-2011 05:00 PM |
| Option One - how big | Willallison | Option One | 43 | 12-20-2005 06:44 AM |
| vacuum bagging or vacuum infusion | Eisa Hasan | Fiberglass and Composite Boat Building | 10 | 03-29-2005 04:25 PM |
| Vacuum bagging with fabric | brevell | Materials | 1 | 09-15-2004 02:16 PM |
| Vacuum Bagging Question | turnershells | Boatbuilding | 0 | 01-20-2003 01:33 PM |
