Old 05-19-2005, 02:41 AM
Scratchy Dan Scratchy Dan is offline
Rep: 10 Posts: 9
vacuum bag hull drying
Just a thought? Is it possible, realistic to use vacuum bagging to dry a waterlogged hull. I know moisture us supposed to dissapate when put under a vacuum. Will it work to get the last drops out after a month of air drying?
Dan
Old 05-19-2005, 02:55 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Sure, there is even a company selling a system that combines vacuum with heat-blankets to increase evaporation.
Yokebutt.
Old 05-20-2005, 12:49 AM
Rep: 10 Posts: 9
more info
Thanks for that. Do you have any info on the manufacturer? How much pressure do you need and how can you tell when it's dry? The boat is in the tropics so after a month of drying hopefully a bit of good dry weather and a vacuum finish, maybe I won't need the heat blankets.
Dan
Old 05-30-2005, 06:30 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
If I recall correctly, the company and the system is called "Hotvac".
The should be at www.hotvac.com. Good luck with this. Here in NL it seems to work very well.
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
