Old 12-09-2010, 03:42 PM
king852 king852 is offline
Rep: 10 Posts: 6
Vacuum Bag
please can anybody tell me the maximum length of boat where i can use vacuum bag in a correct way
Old 12-09-2010, 04:43 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
I have bagged up to @18 Meters one shot,the main thing is setup and having the right equipment.Talking wetbagging and corebonding right?
Slippery when wet.
www.cheetahcat.com
Old 12-09-2010, 05:07 PM
Rep: 10 Posts: 6
so would you tell me exactly and step by step what is the right way yo get a good result in case of 15 m boat
Old 12-09-2010, 05:08 PM
Rep: 10 Posts: 6
Old 12-09-2010, 06:33 PM
Rep: 84 Posts: 661
Sir sure, what are you doing? That will help me direct you a little better.
Slippery when wet.
www.cheetahcat.com
Old 12-09-2010, 09:12 PM
Rep: 10 Posts: 6
actually i am building a boat of about 15m length, 3.5m breadth and 3.5m depth and i used to follow the hand layup method and i want to try the vacuum bag but i don't know how.
so please i need you to explain some points to me:
1- may i put all the dry reinforcements in the mold then cover them with the bag and connect it with resin supply, pump and pressure gauge then secure and start the pump.
2- and if so, how can the resin reach the upper side edge of the mold and how can if be well distributed.
3- or shall i laminate the reinforcements with resin first then start bagging and how can i prevent resin curing before i complete lamination.
Old 12-10-2010, 01:20 AM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
Here's how we do it on a smaller hull.
Gel coat mold.
Skin coat. Being a wet layup layer of mat. This helps with print through, sealing for vacuum, protecting the gelcoat when working in the hull.
Load in all the material and core dry.
Bag with plumbing.
Vacuum it all down.
Shoot in the resin.
The green lines are feed lines, the air is pumped out around the top border. We start flowing the resin at the bottom. As the hull fills, we close off the lower lines and open higher ones.
When the entire hull is filled we close 'em all off and wait for it all to kick.
Start small, there is a steeper learning curve to this than it looks.
Hope this helps.
Good luck!
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 12-10-2010, 12:08 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Size does not matter that much. I know of a 90 meter project (1 shot...)
I I do not forget I will post some pictures of 15 meter(ish) boats, being infused.
Old 12-10-2010, 02:15 PM
SeriolaDumerili SeriolaDumerili is offline
Rep: 10 Posts: 20
here you can find some informations - 24metres carbon with many pictures:
http://www.polyworx.com/apz/slov1/
hth
Old 12-10-2010, 02:34 PM
Rep: 84 Posts: 661
1. You will need to bring in someone to help you setup the first infusion,there is some training involved,strategies and equipment considerations,otherwise it goes to the dump.
2. the feeders can be staged so when the resin front reaches a point then a second line can be opened if this is necessary.
3. there are inhibitors (for the ester resins)that can be used to control the gel time,you can get whatever time is needed, they are common in the industry,Working alone I would set the geltime for @4 hours.
Slippery when wet.
www.cheetahcat.com
Old 12-19-2010, 02:50 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Thats like asking how long is a piece of string !!
It depends of a lot of things .
We were doing the total inside of 35 foot yachts Gun-whale to Gun-whale in one shot but it took some planing to get to that stage !!
Timing and knowing what you are doing and knowing and understanding the materials you are using is all important .
Getting just one part of the operation wrong and you could loose the lot .
Biggest panels i have made were 16 mtrs long and 4.5 mtrs wide using 50 mm core stuck down with core bond . Started at one end and worked to the other and laid all the peel ply and bleeders a scrim and bag with pipes as we went till we got to the last and closed immediately the last sheet of core was laid and covered with all the ply's etc , Had a really big vac system with lots a stowage ! Open the valve and had immediate suck down in less then a minute and final vac in 5 minutes . Minimum of 6 persons well schooled and experienced people to do those sizes of panels and 100% of everything at you finger tips along with spares like tape ,scissors spare buckets of core bond , boxs of gloves etc etc , including spare catalyst bottles etc etc and numerous other things . Once the bucket of core bond is catalyzed and mixed there is no stopping for any reason .
Making beautiful boats is a passion never a chore !
Old 12-19-2010, 05:52 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...do you mean simple vacuum bag, or are you referring to resin infusion...two different things in reality......even though the resin infusion is done by vacuum.....
Old 12-19-2010, 05:16 PM
jim lee's Avatar
Rep: 217 Posts: 336
Landlubber, what in the world is your avitar picture of? I've finally given up trying to figure it out.
-jim lee
J/35 No Tomorrows
Old 12-19-2010, 11:55 PM
Landlubber's Avatar
jim,
Have a look here, it is detail of the real Landlubber, I am only a copy.....
http://www.skotolsen.com/purchase/landlubber.php
Old 12-20-2010, 01:26 AM
Herman's Avatar
Resininfusion.info
Oh no! A self portrait! I do not even have an avatar, I believe. Will create one...
On infusion: If you have the chance, lend yourself out to a boatyard doing infusions. You will learn enough to be able to do smaller infusions, and read and understand discussions on larger ones.
I am preparing a document explaining the process a bit further. (but give me another couple of weeks)
cheap vacuum bag materials/sources sigurd Materials 9 02-10-2009 02:42 PM
Is CoreCell Air Tight.. Leaking Vacuum bag FirstLight Boatbuilding 6 01-10-2008 03:49 PM
Vacuum Bag the whole boat? A Fn Noob Fiberglass and Composite Boat Building 9 01-02-2007 10:21 AM
Recommended vacuum pumps for vacuum bagging? James Mills Materials 1 12-17-2006 03:11 AM
vacuum bag hull drying Scratchy Dan Fiberglass and Composite Boat Building 3 05-30-2005 05:30 AM
