Old 02-20-2011, 09:27 PM
dlewis101188 dlewis101188 is offline
Vaccuum Infusion Table
Hi everyone,
Ive got a project im trying that im trying to figure out the best way to construct it. I have to create a 14' x 14' infusion table that i can bend both convex 6" and concave 6" from the center of the table. I was thinking a thin layup with tooling resin and gel coat at 1st but im afraid of it fatiguing and cracking because of the bending it will be enduring. I would rather find an alternative to this such as some kind of sheet good or aluminum, but i cant seem to find anything in 14' or greater widths?.. Any suggestions or ideas would be greatly appriciated.
Doug
Old 02-21-2011, 02:05 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
A sheet of steel? Most truck sides are made on a steel mould.
Just be careful with welding: I would rather glue fittings on the backside.
Old 02-21-2011, 09:35 AM
Rep: 1493 Posts: 7,447
Formica or plexiglass will work.
MODU table ejim Class Societies 9 05-26-2010 10:09 PM
GM and KG limit table xhanasico Stability 5 06-01-2007 02:07 AM
table of offsets aqua_ambulat Boat Design 2 09-17-2005 07:07 AM
Table off Offsets? Guest Fiberglass and Composite Boat Building 1 10-03-2004 08:14 AM
Flat vacuum/infusion table guest Boatbuilding 4 05-05-2004 05:55 AM
