Old 10-13-2005, 10:21 AM
MilitaryPopo MilitaryPopo is offline
Rep: 10 Posts: 28
V8 MP350ANI problem (1991?)
I have a 1989 Renken Bowrider with a V8 MP350ANI motor in it (i was told by the seller that it is a 1991 model motor). I am a couple problems with the motor, could be the same root problem though. When I first put the boat in the water, it is impossible to immediately put it on reverse, the motor stalls out no matter out many times I try. It starts fine, just stalls out once it is thrown in reverse. After the motor gets warmed up, it usually doesn't have a problem shifting out of drive, but every now and then, when I shift into neutral or reverse, it will still stall, even though the engine is warm by then. I don't know a whole lot about motors, I was planning on this one being my intro to motor work as I am rebuilding the whole boat and planned on tearing down the motor as well. Any help y'all can give me would be greatly appreciated.
Mike
Old 10-17-2005, 05:14 PM
Rep: 1493 Posts: 7,447
I don't recongnize the model number. What make is the motor and drive?
Old 10-17-2005, 11:58 PM
Rep: 10 Posts: 28
the operators manual that the original owner gave me with the boat is from Marine Power INC. and handwritten on the cover it says: 5.7Liter, 260hp, Mod. No. MP 350 ANI and Serial No. AN890742215I. That is pretty much all the data I have on the motor. When you say 'drive', I'm guessing you mean the outer drive, I beleive it is an OMC Cobra, but will have to check on that tomorrow and get back to you. Thanks a lot for any help you can give me.
Old 10-18-2005, 05:26 AM
Rep: 756 Posts: 3,328
I would consider looking at the drive , not the engine first.
If it stalls when cold on getting shifted into reverse , it would seem reverse is requiring more power than the engine has cold. Thats not normal .
Any shift adjustments , to be sure its not attempting to be in two gears at once?
FAST FRED
Old 10-18-2005, 08:26 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Check the shift linkage in the sterndrive as well as the cables from the helm to the drive. If ithey are properly aligned, my next guess would be the hydraulics in the lower unit. I agree with Fred that the drive is likely the culprit, and I think your engine is probably fine.
Old 10-19-2005, 12:30 PM
That is a rebuilt unit by Marine Power. The gear oil may be too low. That can make it drag or stick.
OMC Johnson 50 hp 2001 engine problem Guest Powerboats 8 11-05-2008 08:57 PM
Performance/Handling Problem Boa Powerboats 11 08-10-2006 06:36 PM
Tricky hull modelling problem Andy Software 3 10-13-2005 10:42 AM
Water in Oil Problem ScCoghill Propulsion 3 06-05-2005 01:09 AM
Sea trials-one major problem Powerboats 6 05-10-2004 12:35 PM
