Old 06-02-2009, 09:40 AM
pescaloco pescaloco is offline
Rep: 19 Posts: 231
Uv light cured resins ?
Hey guys,
I have a sales pearson from a company called Admmiralty marine coatings contact me regaring his revolutionary product.
His claim is that they sell a Uv light cured resin system that can be used in the following manner (it may be multiple different products) not sure yet but the premise is the same (instant cure time, with in seconds and no prep for recoating)
applications:
Varnish woods
clear coat for gelcoat: "Never to wax or buff again"
marine construction of fuel tanks
and others I am sure
I did a web search and can not find anything that looks like (to me) a legit boat yard or organazation that endorses the product.
Any body ever use this stuff or even heard of it.
My primary business is marine detailing and cosmetic repairs, it sounds like snake oil to me but is interesting
thanks
Old 06-02-2009, 11:20 AM
apex1
Lookup the "Vetus" catalogue, they use a UV hardening resin for replacement tanks.
Regards
Richard
Old 06-02-2009, 10:22 PM
Rep: 19 Posts: 231
Thanks will do,
To saw you can overcoat gelcoat and never have to wax again seems harder to believe than some of the other claims.
Please though if any one has first hand info on the Admmiralty coatings let me know the scoop
Old 06-02-2009, 11:25 PM
Rep: 527 Posts: 792
UV curing resins have been available for at least 20 years now. These guys are the premier manufacturer.
Jimbo
Old 06-03-2009, 04:07 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,144
Polyester resin cures when subjected to UV.
I once brought a plastic can half full of ICI polyester resin for a friend, but he was not at home, so I left it on his porch in the morning. The next day he called me and asked why I gave him a solid block of plastic.....
Old 06-03-2009, 10:14 AM
Rep: 19 Posts: 231
Thanks guys,
I have heard of Sunrez, but allways thought it was a naturall UV light souce (the Sun) and that cure times were more like a STD. resin in time frames.
Ok so ever heard of an overcoat (that works) to a finished gelcoat surface that would give a surface that required no maintenance other that washing for the life of the boat ?
Since I am in the cosmetics business that is what really stuck me as a bold claim
Mist before epoxy cured tuantom Fiberglass and Composite Boat Building 12 05-06-2009 12:24 AM
How to prep cured epoxy for next layer? H180DSC Fiberglass and Composite Boat Building 9 07-14-2007 01:09 AM
trim cured Kevlar laminate to get smooth edge JV_Comp Fiberglass and Composite Boat Building 4 04-23-2005 07:33 AM
different resins? GrantC Materials 2 02-16-2005 08:41 AM
UV light cured resin TheFisher Fiberglass and Composite Boat Building 0 06-17-2004 01:39 PM
