| PAR gave good advice. I usually tap the epoxy once it has gone through an initial cure but is still somewhat soft. This works well for smaller tapping screws but engine lugs might be too big. If you can work with studs cast in as PAR described that would be best bet. In this situation I probably wouldn't do the wax trick as it might mess with your bond (unless you are really comfortable with what you are doing). If you ever had to remove the studs they could be cut/drilled out and re-epoxied for repair. |
| The mounts aren't rotten unlike the stringers, however they are stripped out hence why i was replacing them. So it sounds like perhaps i can leave the original mounts and just repair with epoxy? is this better than replacing the wood or a patch up? |
| If the surrounding wood core is sound and only the holes are stripped repairing the holes only would be fine. Wood must be dry however. If its damp it will need to be dryed or alternatively use an epoxy that will cure in presence of moisture. This process of making epoxy filled "beds" for fastners is common even in brand new construction. Many foam core materials for instance just don't have the density to retain screws. There are a number of other advantages as well. If you don't have the west system user manual I would suggest getting it. It covers this process and a number of others. I think its free or maybe just a couple of bucks. |
| I'm just following along here. I'm wondering about trying the same type of technique on my flybridge. On my 73 Silverton restoration I'll need to reattach the flybridge once the cabin top is in place. By the time we hoist the one piece fiberglass bridge up there the cabin top will be completely finished and painted. I figured on putting an old carpet section down to protect the finish while I position the bridge. So....the bridge was attached to a 1" thick cabin top using lag bolts. These had a course thread and are not very long (obviously). I'm wondering what some of you think about drilling into the cabin top (very carefully, it's only 1" thick) using, say, a 3/4" or 7/8" Forstener bit. I'd get a flat bottom hole which I could fill with epoxy (use silica?) and then tap a machine screw into. This would give me better holding power I'd think and better protection of the cabin roof from water infiltration. I'd then install the original stainless bracket which would cover the hole. Any alternatives or suggestions? Thanks! Missinginaction |
| Use a "T" nut or "blind" nut, bonded into the roof. The epoxy bonded trick would work, but I like the idea of metal holding the threads if I want to remove things or really crank down on them. |
| Gotcha PAR. I've used tiny blind nuts over the years on radio controlled model airplanes. Thanks again for the tip, I'll file it away. MIA |
| 9 month old poly resin | pescaloco | Fiberglass and Composite Boat Building | 16 | 02-11-2008 09:21 AM |
| Tying poly and epoxy repair areas together | sbklf | Fiberglass and Composite Boat Building | 7 | 12-16-2007 01:22 PM |
| epoxy and poly? | COLD-EH' | Fiberglass and Composite Boat Building | 9 | 12-26-2005 06:00 PM |
| What type of resin to use? epoxy or poly. for this hole in Bow? | J-Bird | Fiberglass and Composite Boat Building | 4 | 12-25-2005 11:21 AM |
| poly vs epoxy manufactured to repair | LKJR | Fiberglass and Composite Boat Building | 4 | 08-24-2004 02:56 PM |
