| Usage of microsphere, microballoons and silica Hello, i want to learn more about the usage/caracteristics/effects/mixing of microballoons, microsphere, silica and graphite powder with epoxy. when and how do you use it ? do you have interesting source of information explaining this ? Txs |
| miss dynamite, they are help substances in mixing synthetic resins for various techniques and applications. forexample chalk is cheep and lowers laminate pricing and improves stiffness. shrink is reduced but a laminate gets more sensitivity to moist. microballoons are hollow glass spheres added to the resin to get a lower weight while sanding is easyer. often used in plaster and fillets. aerosil is a lightweight powder used to chance viscosity used for example on vertical applied resins without drip. aluminum nitrate added to resins is flame retarding. needs to be 3/4 of the resin though. there are pigments and more additives. microspheres are solid i believe and good for... gee forgot, someone knows better i'm sure. used with care these additives can really do a good job. |
