  #31
Old 01-31-2012, 06:23 PM
Gian Milan Gian Milan is offline
Previous Member
Rep: 0 Posts: 0
wanting to put the bottles in a wooden template, there is the opportunity to fill them with polyurethane.
the cap should be closed with care.
The bottles become rigid. helps in case of collision.
If you use the bottles to stop requiring that make noise, they shall be fitted with silicone or glue.
WARNING!
the floating material, once closed lockers that cover, must be absolutely unable to get out!!
when the boat sinks, the bottles are put to push hard!
In addition to the required weight of the boat, be sure to calculate the weight of the load.
  #32
Old 01-31-2012, 09:26 PM
therigwelder therigwelder is offline
Rep: 10 Posts: 30
OK i figured i can get 18 cubic ft of blue Styrofoam into the sides of the boat and at around 55 lbs of resistance per cubic ft i will have right at a 1000 lbs of resistance.will this be enough to keep the boat in question safely afloat?
  #33
Old 02-01-2012, 03:11 AM
Previous Member
Rep: 0 Posts: 0
calculation by the specific gravity
If you know that your boat is made ​​of a material that has a specific weight ... 2.8 (aluminum case) weights the boat, divide the weight by 2.8 to get the thrust of the boat upwards.
Engine and more should be placed in the shipment.
If your boat has specific gravity of 1.6 (our friends are sure, I have not seen the boat), boat weight, divide the weight by 1.6 and you push the boat up.
calculating the volume.
you start to measure the boat with great care.
You will get a measure in cubic feet.
cubic feet * 28 * 2.2 = lbs of upward thrust of the boat.
RULE
If your boat is made ​​from material with specific gravity less than 1 (eg cork), it floats on its own.
Much of the wood has a density less than 1.
The ships sank to the load, which could overcome the upward thrust of the wood.
  #34
Old 02-01-2012, 10:17 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Originally Posted by therigwelder View Post
okay your suggesting that i fill the boat hull full of empty 1 liter plastic bottles.then deck and fiberglass over them.ok i understand the floatation principal but its rather unusual lol.one liter bottles are definatley cheaper than a&b part foam.I am a redneck from mississippi and i have to thank you for the good laugh i just got.wonder how it would work with aluminum coors bottles rflmao
No joke. Bottles are better and won't absorb water weighing down the boat.
Hoyt
  #35
Old 02-01-2012, 10:18 AM
hoytedow's Avatar
Resistor
Originally Posted by Gian Milan View Post
my English is disgusting ...
maybe I'm the one who did not understand
Your English is improving.
Hoyt
  #36
Old 02-01-2012, 10:44 AM
Previous Member
Rep: 0 Posts: 0
I'm here for three reasons. 1) I want know what is happening in American society 2) I want to build a aluminium ca 10 meters and would like to discuss the projects 3) I must improve my English. 1 and 3. .. work in progess!
I was thinking about bubble wrap as valid float. We should put it in a polythene bag, welded o clsed with glue.
Even if idea to use polythene bags full of polyurethane and bottles is ....fashinating!
Someone use ping pong balls...
  #37
Old 02-20-2012, 06:59 PM
Rep: 10 Posts: 30
I decided to use pink foam board,i am posting pics.I put it in the bottom for now but i plan to foam the gunwales after i get the sole glassed in.I used 4 sheets of 4x8x1/2 foam.not really sure of the cubic footage to determine bouancy.can i use some "great stuff"foam to fill in any voids?
  #38
Old 02-20-2012, 07:02 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Any of those two part spray foams will soak water for sure so dont do it !!
Making beautiful boats is a passion never a chore !
  #39
Old 02-20-2012, 07:59 PM
Rep: 10 Posts: 30
I figure i have 8 cubic ft.of foam.I figure that to be 440 lbs of flotation.I estimate i will place around the same amount of flotation in the gunwales giving me 880lbs of resistance and thats not counting the resistance of the boat itself.hopefully this is enough floatation to keep it afloat should a bad situation happen.What you all think?
Embedding aluminum structure in urethane foam -- issues? Foreigner Materials 17 10-04-2010 09:45 PM
Advice on bonding to urethane foam BobMan Fiberglass and Composite Boat Building 6 05-30-2009 10:51 PM
urethane foam in stringers fishweed Fiberglass and Composite Boat Building 10 08-20-2006 10:32 PM
polyester matrix over urethane foam tjantti Materials 0 09-21-2004 04:21 AM
urethane E.V.O. Materials 2 08-29-2003 05:49 AM
