Old 03-27-2007, 04:21 PM
SamSam SamSam is online now
Rep: 502 Posts: 1,683
I used it to make a boat like Carolina Skiff does which uses 3x3" "logs" of foam, so you end up with two skins separated 3" with a fiberglass connecting rib every 3". It's not regular sandwich construction.
Old 03-27-2007, 04:27 PM
rapscallion rapscallion is offline
Rep: 129 Posts: 412
Interesting. I've never heard of that before. How is the boat holding up?
Old 03-27-2007, 05:05 PM
The boats fine. Here is the Carolina Skiff patent, which expired a few years ago. When you get there (if you go), click on "Images", figure 4 shows how the glass is laid around the logs. Sam
http://patft1.uspto.gov/netacgi/nph-...&RS=PN/4495884
Old 03-27-2007, 05:16 PM
If you go to the site, on the first page that comes up, the one that I said to click on "Images", if you scroll down there is a list of blue numbers. Those are all the older patents that the guy shows to prove that his invention is new and different. They are interesting to look at as they show different ways people invented to make stronger hulls with sandwich type construction. Sam
Foam core construction? Itchy Fiberglass and Composite Boat Building 10 05-03-2007 08:51 PM
Which Foam for Core? Toby P Fiberglass and Composite Boat Building 5 05-06-2006 05:44 PM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 10:12 PM
Selecting foam core TomE Materials 14 01-07-2006 04:18 AM
Foam core Hotrod99 Fiberglass and Composite Boat Building 9 09-06-2005 01:24 PM
