| Unidirectional glass , anyone used it to build boats from ?? I am interested if anyone has ever used just unidirectional glass to build hulls with !! OR even considered using just unidirectional Has anyone ever explored its properties and capabilities for hull construction as a solid glass layup or used in conjunction with a core as the outer and inner glass !!. ![]()
| Just locally.. too much work to do that IMHO.. |
| Why bother, when you can use biax or triax to get the fiber orientation you desired with much less effort? You're going to need the cross grain strength of fiber alignment anyway, so why lay them down one at a time? For example if you use two layers of 45/45 biax, canting one 11.5 degrees from paralleling the LWL and the next 11.5 degrees in the other direction. Your laminate is 4 layers thick with a crossed fiber orientation, on a 11.5 degree separation, all arranged longitudinally. |
__________________ Slippery when wet. www.cheetahcat.com |
Triax comes in different originations , 0/45/45 for the outer skin you can get 90/45/45 for the inner skin this is as close to what i have used on a couple of boats . I then used solely uni after that , this ended up stiffer . 0 being the centre line of the keel outer skin 30/60 then 45/90 for the inner layer ,was only 4 layers thick of 400gram with a 125 gram csm between each layer , solid glass with a glass grid frame inside and a glass floor with a 18mm thick foam core . no wood any where to get wet and go rotten over time !!! Even being thin it was incredibly strong and light weight because uni takes the minimum amount of resin to wet out with Vinylester resin if you skin with peel ply on the final layer . i found that i ended up with very little wastage when i thought about the cutting of layers , Far less than using a triax or a biax glass Was used for a 16 foot hull , used in rough water so got a pounding all the time . ![]() ![]() ![]()
| Carbon Fibre Unidirectional cloth | Ramona | Sailboats | 8 | 09-23-2007 02:53 PM |
| I want to build a fiber-glass bay boat!... | mufit | Powerboats | 5 | 09-08-2006 01:28 PM |
| Unidirectional Fiberglass | Inquisitor | Boat Design | 19 | 12-14-2005 01:41 AM |
| How do I build a mast out of Carbon Fiber or glass | Lowcarb | Boatbuilding | 30 | 09-27-2004 10:09 AM |
| Glass Bottom Boats | Arrowmarine | Boat Design | 6 | 08-20-2004 02:27 AM |
