Old 10-07-2010, 12:12 AM
wrbowcal's Avatar
wrbowcal wrbowcal is offline
Rep: 10 Posts: 22
Under the waterline paint? / gelcoat? / flowcoat?
I was talking to one of the guys at a store where go to get supplies for my boat I am working on and he said I could re apply gelcoat to the hull by using a roller? Can this be done? Gelcoat is too thick for that is it not?
Old 10-07-2010, 06:43 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Yes, it can be done. Sand the bottom really well, then apply gelcoat to the bottom. I suggest applying at least 2 layers, with the last layer some parafin added to it, so it cures without a sticky surface.
Then take a piece of sandpaper, and sand everything smooth. Use finer sandpapers, up to grit 1000 or finer, and polish up the bottom. It is a hell of a job, but it can be done.
Of course, under the waterline, you could also use any bottom paint of your liking.
Paint below the waterline Onthehard Materials 1 12-12-2009 09:46 AM
Help with paint/gelcoat color GoSlow Boat Design 1 08-10-2008 09:27 PM
Should I paint or re-gelcoat? brad123 Fiberglass and Composite Boat Building 39 03-25-2006 04:54 PM
gelcoat over paint gofishing Boat Design 2 04-12-2005 08:20 AM
Gelcoat vs. paint (LP)? mattotoole Boatbuilding 5 03-08-2005 12:46 AM
