Old 05-28-2009, 10:16 AM
pescaloco pescaloco is offline
Rep: 19 Posts: 231
Un ballanced laminate
Hey guys,
If you can with out a lot of specs try to answer
I am making a pilothouse for a 27 foot sportfisher aprox dimensions 12ft long x 8 feet wide.
Construction consists of 3/4 in foam panels on a male mould
outside laminate which is complete is 1.5oz matt / 17oz cloth or 1708 Nytex in some spots / 1.5 oz matt
I am afraid that it is getting too heavy, is it ok to go lighter on the inside or is it generally better to have a ballanced laminate
Thanks
Old 05-28-2009, 10:47 AM
Rep: 1397 Posts: 7,215
To answer that would require to study the design and recalculate the laminate. I don't think you can go much lighter than 1708 on that size though
Old 05-28-2009, 03:44 PM
wet feet wet feet is offline
Rep: 99 Posts: 258
It's always desirable to have a balanced laminate,unless a composite engineer can give you a good reason not to.
Old 05-29-2009, 08:57 AM
Rep: 19 Posts: 231
thanks guys,
I appreciate your feed back
laminate programs koanda Boat Design 3 11-30-2007 05:46 AM
laminate thickness sarciccia Fiberglass and Composite Boat Building 2 02-07-2006 08:54 PM
Geocomposite for laminate hobbyman Fiberglass and Composite Boat Building 0 05-26-2005 11:42 AM
Laminate schedule jfblouin Fiberglass and Composite Boat Building 3 01-23-2005 01:39 PM
Any example of a 60 footer laminate? Gades Materials 10 05-24-2003 04:42 PM
