Old 02-04-2004, 07:48 PM
quicksail quicksail is offline
Rep: 25 Posts: 58
Ultra-lite construction ideas???
Here's alittle question for all you boatbuilders out there. I am design an ultra-lite 27ft sailboat. The problem is I don't know that much about the latest composite methods out there.
The problem is this: I need to build a 27ft hull, deck and internals that tip the scale at approx. 300 Lbs. Now tell me is this achievable? The surface area of the hull is 244 sq. ft. and the deck 150 sq. ft.
I am open to any sort of ideas as this is just a design project idea. I see other sailboats such as the JS9000 and sierra 26 that have made very light hulls but I don't know what they do.
Any help is greatly appreciated
Cheers
Old 02-07-2004, 10:07 AM
Rep: 1397 Posts: 7,216
You need to specify more closely. If the sailboat can make do with 100 sq.ft. of sail and a completely bare interior, it is possible. If you are planning on a more conventional boat, I don't think so.
Old 02-28-2004, 11:49 AM
geofish
A self designed sitka spruce frame with kevlar reinforcing and dacron skin.
Old 02-28-2004, 06:57 PM
A skin on frame hull is very light. Can you post some of the dimensions of the framing?
Old 03-07-2004, 06:01 AM
spartin spartin is offline
Rep: 10 Posts: 17
pe preg carbon
Old 05-07-2004, 10:52 AM
Buckle's Avatar
Buckle Buckle is offline
Composite Engineer
Rep: 10 Posts: 83
I colleague of mine is in the process of building a 10m cat. Anyway one of the hulls is made from prepreg. It only ways 80 kilos. However due to the lengthly layup procedure, we resin infused the other hull of the cat. That weight 100kilos. for its strength and size its super light. The key is to think coring. We used honeycomb on the prepreg half, and balsa on there other half.
Naval Architects Dubai chrisalex Services & Employment 25 03-28-2007 09:36 PM
which construction method? mjpetersen68 Boatbuilding 12 09-26-2005 04:48 PM
Direct female mold construction... Brant Williams Boat Design 5 02-20-2005 08:19 PM
1/4" balsa core construction JimT Boat Design 5 02-11-2005 11:28 AM
uncertain of structural matrials in new project donjames Metal Boat Building 9 08-15-2004 02:22 PM
